Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Brushes fitted new brushes on hotpoint aquarious, drum still will not spin???
  • dan muggeridge May 11, 2010
    Do you have power and get lights on the front?
    If so is the belt from the spin motor to the drum in place?
    Also check your new brushes have the cables connected properly.
  • 108 Answers
If replacing the brushes has not fixed then its most likely the motor is duff.
Posted on Feb 28, 2008
Hotpoint aquarious making loud gring noises and sometimes does't start
sounds like motor brushes. physically check your motor for black power, that's a sure sign of brush wear. could be seized bearings, try spin the barrel of the washer by hand, if it's stuck/very hard to turn, thats a sure sign of bearing seizure.
Nov 10, 2013 | Hotpoint Washing Machines
My Hotpoint WF865 has stopped spinning,every other feature works but it refuses to spin.HELP!!!
Fit a new set of motor Brushes if they are worn,this can cause this also you must make sure its not too LITTLE in the drum as this results in out of load balance control cutting in ....
Feb 17, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
HOTPOINT AQUARIS WMA40 WONT SPIN
Try changing motor brushes, this is most likly problem. You will need to remove motor to do this. Cost if you do them yourself is about £18.00
Feb 13, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIES WM63 , NO SPIN SPEED- MOTOR WORKS OK ON WASH, BRUSHES LOOK OK.
If the brushes are less than 3 or 4 mm long, then they need replacing.
If still no spin , but washes o/k, then the high speed part of the motor windings could be faulty, which entails replacing the motor.
Please rate my solution.
Thankyou
Jan 19, 2010 | Hotpoint Washing Machines
Hotpoint Aquarious 1200 IE When spinning the drum ocsillates violently and is very noisy.
Remove drive belt, and spin drum by hand, if noisy or rough, then bearings have failed, if no noise, then could be suspensioon leg problem.
Tghanks.
Sep 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarious 1000 de luxe
You need to check the lateral movement of the drum if it moves by more than 1-2 mm then the bearings need to be replaced.
Apr 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
125 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
