Question about LG DLG7188 Gas Dryer
My lg dlg7188rm gas dryer will not heat. the gas
My lg dlg7188rm gas dryer will not heat. the gas does not come on at all. and yet the gas is turned on. was working last night just all the sudden stopped. Help
  • jasonbbates Feb 01, 2010
    Took off the top of the dryer and i can see the ignitor come on. took off the front of the dryer and i see three sensor that look like they monitior something in order to open the the valve for the gas. what is the best way to check these sensors to make sure they are working correctly. one looks like a photocell that is directly to the side of the ignitor and the other two are directly oppossing each other. not sure if they are some type of heat sensor. the are however wired in series. any ideas?
  • 105 Answers
Sounds like you need an ignitor part number 5318EL3001A but you will need a gas technician to work on this legally. Best off to call a reliable service company such as Sears.
Posted on Feb 01, 2010
Testimonial: "great explanation. thanks,"
  • Craig Harvey Feb 01, 2010
    The ignitor might come on which is normal but if it doesn't get hot enough it won't let the gas valve open. The one that looks like a photocell directly on the side of the ignitor is called the flame rectifier which will turn off the ignitor when sufficient heat is provided. Best off to call a reliable service company such as Sears as this product requires a gas technician legally as if you do something wrong your insurance companyn would not cover you.
2 Suggested Answers
iwillfixforu
  • 619 Answers
SOURCE: Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Lg dlg7188rm - My dryer is not getting hot. When I start a cycle the ignitor comes on (orange glow under dryer) and then gas comes on (blue glow). After about 30 seconds both shut off.
There are two or three sensors in the heat exchanger and another one or two in the fan housing. Check them all for continuity. One in the heat exchanger is resettable
Jul 22, 2017 | LG DLG7188 Gas Dryer
Dlg2522w gas dryer not heating, cleaned vent, reset, unplugged, still won't heat, motor replaced last year
I tired the reset on the over temp. Did not work. How do I check the igniter/ gas valve and thermostat?
Apr 26, 2012 | LG DLG5932W Gas Dryer
Dryer dlg7188rm hums when start button is pushed and you hear a subtle clicking but drum will not actually turn on and start drying. problem happens sporatically.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 23, 2011 | LG Dryers
Dlg7188rm makes loud banging noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
May 05, 2011 | LG Dryers
I have an LG dryer Model # ddle7177rm/dlg7188rm.when we start the dryer it starts to heat then stops and it blows cool air. the ducts are all clean.
Hello
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG Dryers
Tromm LG gas dryer 5988 gas wont turn on says DRYING but it's not Everything else works
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | LG DLG5988 Gas Dryer
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
Dryer will not get hot
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Feb 01, 2010 | LG DLG7188 Gas Dryer
Open Questions:
LG DLG7188 Gas Dryer Logo
957 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
