My Onkyo TX-DS777 won't come off of standby mode. I've tried other suggestions including unplugging it, taking off the casing and looking for anything unusual, checking all the wires, etc. Nothing seems to work. Is there a particular area I should be looking into once the casing is removed?
  • 1,068 Answers
Yes the heat sink (aluminum block) in side has a few transistors on it. see if there is any burns or black char if so the problem is in the amp. if not it may still be there but could also be in the power supply.
also any corrison or cold solder joints ( broken or cracked solder pads), anything burnt or broken poped.
Posted on Feb 01, 2010
Tx-ds777 no sound from front speakers on a speakers work on b but if I run a and b the center and surround stop working
Hi MJ, If you run your B speakers you will drop your 2 surrounds as the B speakers are meant to be used in a different room. I would suggest that you give us a call so that we can try some troubleshooting, please call our Product Support Team at 800-229-1687, Thanks, JT
Aug 19, 2015 | Onkyo TX-DS777
Can i connect an ipod to my Onkyo tx-ds777?
You should be able to do it with the right adapter cable.
Jul 21, 2014 | Onkyo TX-DS777
Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Apr 26, 2010 | Onkyo TX-DS777
Home Audio problem
Have you looked in the manual for TROUBLESHOOTING: No Power?
It suggests unplugging the unit for a short time, then plug it back in, then check for a blown fuse, then take it to the ER.
Mar 16, 2010 | Audio Players & Recorders
Hello, i've had a problem with my onkyo tx-ds777 for some time now. i've noticed when it warms up and runs for a while, it cuts off by itself. you can only turn it on when the room temperature is cool...
What I've found was bad solder connections on the audio output board.
I Don't know if you are familar with soldering procedures or not.
I would highly suggest not trying it yourself, if you're not a soldering professional. You WILL cause more damage to the unit, ok?
Check with your local audio servicers for estimates.
Dec 01, 2009 | Onkyo TX-DS777
My Onkyo TX-DS777 lost power. I believe this to be a blown fust, but am uncertain, any thoughts?
It seems like the internal fuse to me, too. But you could check to make sure that the receptacle works (maybe you've got a tripped breaker).
The manual also suggests unplugging and re-plugging the unit to clear "external noise" from the "computer circuits," but something tells me that you've already tried that.
Sep 20, 2009 | Onkyo TX-DS777
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Remote problem on onkyo TX-DS777
ya thats the universal remotes having list of codes .
first you set up with the code that should match for your revelent make and model of your dvd player.
so you just go through with codeing list that accompany with purchaseing of universal remote.
and set up with code particularly for your make and model of your dvd player.
and finaly try with your dvd player.
ok all the best.
Oct 08, 2008 | Onkyo TX-DS777
Onkyo TX-DS777 Problem
man I think i have the same problem....
i push the power button but immediatly the LED turns off. I cheked the fuse but thats not the problem. Please if you solve your problem let me know...
my e.mail adress soy_robertog01@hotmail.com
sorry if you dont undersatnd me in some parts..im not very good writting english haha sorry..
Jun 22, 2008 | Onkyo TX-DS777
Tx-ds777
Same thing happened to our TX-DS777.
Took it to a locate electronic comany and they told us it was the
DSP board gone bad. Est 425.00 to 450.00 to fix.
Aug 16, 2007 | Onkyo TX-DS777
Open Questions:
21 people viewed this question
 Grubhead
Grubhead
