Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Water drips around one of the headers but can't see a crack
  • 366 Answers
It's likely you have either loose header bolts or a bad gasket.
Posted on Feb 09, 2010
2004 chevy cav just had cracked radiator replaced with new one.. now small leak in front and tail pipe dripping water.
No, you should not worry. Tail pipe dripping isn't related to your radiator. It's common especially if your vehicle sits alot.
Small oil leak. You need to find the source of it. Use some good engine degreaser and clean it up. You should then be able to find where it's coming from as you fire it up and check around. I understand sometimes that's hard because things are packed in. How fast are you losing oil? Check the level on your dipstick.
Mar 03, 2016 | Cars & Trucks
True back bar freezing up
Most models have a metal drip collector below the evaporator that has a drain hole in it where the defrosted water goes into before it goes down to the drip trap and then out the drain hose. If the area around the drain hole has cracks, or was punctured during servicing, the drain water can get underneath the tray and run out beside and around the drip tray and never gets into the drain tube and freeze in that location. A careful inspection of this area will reveal any issues.
Aug 15, 2014 | Refrigerators
Toilet flushed then dripping sound at floor level
If you;re sure its under the toilet, look for a crack in the base, especially around the retianing bolts, or the wax bowl seal is gone, needs replacing.
Apr 25, 2014 | American Standard Home
My delta 400 shower is dripping
Take off the shower head and check the rubber washer inside. If it is cracked, off center, or missing, you will have a leak. Also, make sure you are using plumbers tape (teflon tape) around the male threads on the shower pipe that comes out from the wall. Sometimes the pipe leaks at the point where the pipe and showerhead are fastened together, but it looks like the shower head itself is dripping because water always flows downward so it goes over the showerhead at the top and drips off the side.
Nov 20, 2013 | Home
My side by side drip"s
The water is from a blocked drain of the defrost, especially with the water off that's where its from. This tip i wrote will tell ya how to clear that drain http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
Sep 14, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I need a water proof outdoor time for my overhead drip system. Each season I end up buying a new one. My vigoro 196-036 appears to have frozen and busted an internal gasket. Any suggestions
Water timers are made of plastic.
If water is inside any plastic fitting, and there is a freeze, then plastic will crack.
Raindrip, Melnor, Gardena drip systems are made of plastic.
I don't know anyone making a brass drip timer that could expand instead of crack, because the expansion would damage timer shut off valve.
There are 2 strategies to solve problem:
1) Remove timer from cold area during freeze.
2) Wrap heat tape around timer so it will not freeze.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 29, 2011 | Hardware & Accessories
Kelvinator 330 impression series fridge leaks water internally and runs on to bottom shelf. I cannot see where it is dripping from, the drain rack is clear as is the cooling component. This is a regular...
The drip tray is blocked, open your door, about half way down at the back you can see the drip try, on the Right hand side there is a hole where the water drains, poke a plastic straw down there to clear.
Feb 26, 2010 | Refrigerators
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
Cressida still pegs temp guage????????
1st do you loose water from the header tank or water dripping anywhere under car when stopped yes or no if yes to loss of water from h/tank then the problem is you have a Head Gasket blowing compression into the water jacket next to the cylinder,and its only small now but will get worse very soon, so get the Head removed and cracked tested and Head surface ground . Ron
Oct 01, 2009 | 2006 Fiat Pininfarina
Water is leaking from the bottom of the fridge. Why? It is destroying the wooden floor. Refrigerator is Whirlpool Model # ED25UEXHW01
Some water dripping under the refrigerator is normal. There is supposed to be a drip tray to collect it, and there is not so much that it can't evaporate. Check to see that the tray is still there, in the right place, and not cracked. If the drip tray is full of water, then you have another problem. If your air is humid, you would get more water during the defrost cycle and the water in the drip tray wouldn't evaporate very fast. If your freezer door seal is not air tight, you would get more water to defrost. My guess is, the drip tray is out of place or cracked.
Sep 11, 2009 | Refrigerators
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
149 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
