I am unable to initialize my simpletech 500gb disk. It shows up in MY Computer and Disk Management but is in-accessible and shows disk as unallocated.
  • tmorse2 Feb 01, 2010
    will not format.
  • 2,229 Answers
Then you need to go into Disk Management, right-click on the disk and format it.
Posted on Feb 01, 2010
  • Art Ellison
    Art Ellison Feb 01, 2010
    If the hard drive won't format, then it sounds like it has gone bad on you. Is it still under warranty? If so, submit it for replacement. If not, I guess you'll have to get another one.
My lacie 500GB 720rpm external hard drive does not show in 'my computer' as instructions suggest. I have used with my mac previously without any problems, I am currently borrowing a windows computer off a...
you haven't mentioned your os, like windows7 or windows vista. but you goto computer management, by right clicking on the desktop "my computer" icon in win7
or through the start menu choices (which you have to enable with taskbar properties in vista)
or choose help from start menu and enter "open Administrative Tools" to get a quick link
or open the control panel and click on "Administrative Tools"
in any case
start menu, administrative tools, computer management, storage, disk management
once you are running disk management, you can see if the drive is recognized at all. you may be given a right click option to initialize the disk. sometimes, this erases disk data, sometimes it doesn't.
but i doesn't hurt to check out disk management
Jan 13, 2011 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
Turned off raid, unable to access 2nd 160 gig hard
Right click on Computer in the Start menu. You should see manage.
click on manage and you will see some selections the left one called disk management. click that and you should see all your drives. If you disable the Raid you may have to initialize the disk for windows to use it again. right click on the drive and initialize or if it shows up you may have to create a partition and then format.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
I installed the Hitachi 500GB hard drive in my computer running Windows Vista. The device manager recognizes the drive, but I cannot figure out how to format it to store data
If you added the HDD, you will need to open Disk Management (Control Panel, Administrative tools, Computer Management, Disk Management)
The added drive should be listed as disk 1, right click it and INITIALIZE the drive, then format it, then it will be assigned a drive letter and be accessable
Jan 23, 2010 | Computers & Internet
My SimpleDrive 500GB external hard drive is now only recognized as "USB Mass Storage Device" that I cannot access. I have uninstalled the driver and scanned for the hardware and it reinstalls it as USB...
You can try:
  1. another USB cable
  2. try it on another computer
That will rule out the USB and any software/driver issues on your computer. If it doesnt work after that, there could be a problem with the drive itself
Jul 11, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
General questions regarding simpletech simpledrive.
You probably have to initialize and/or format the drive.
Right click my computer and click Manage (assuming windows xp)
Go to disk management
See if you see the drive listed somewhere there. Should show approximately 950gb disk drive
If so right click that drive listed and choose either format, or create partition.
If you create the parttiion, make sure to click quick format, otherwise it will take a long time.
Hope this helps
Jul 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
Simpletech 250G
SimpleTech has problems with their controller board. The HDD inside probably still works fine. You might want to get an external chassis and take the hard drive from the SimpleTech and put it into the external chassis. You will need a sata one.
May 02, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 250GB not working with my computer
This is the email I sent to & received back from the company re: the same problem I was having with it. You don't need any drivers.
PROBLEM: I have followed directions re: plugging device in, still cannot see device in MY COMPUTER. I have also tried plugging both USB's into computer to no avail. Even tried using it on my laptop, still not showing. My desktop is XP & loaptop is Vista. When I go to remove the dirve, it DOES show as Fujitsu, but I cannot acces the drive or locate it elsewhere. I really want to like this, but will have to return it if this issue is not resolvable.
SOLUTION: You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Regards,
SimpleTech Technical Support
May 26, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech hard drive not found by my computer
This is because your bios is only configured to recognise up to 250Gb. what you need to do is download the latest bios updates for you mboard, install them on windows. then you shoud have no further problems with the HDD.
May 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech simpledrive
per the email I received from Simpletech:
Select “Manage”
May 10, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
