Question about Acer Aspire One A150-1049 Notebook
Monitor does not switch on but battery is working
    Problem Solver:
  • 7 Answers
The monitar my not be plugged in
Posted on Feb 01, 2010
How can i fix balackscreen laptop
Take battery out and power out hold on button down for 30 seconds then release don't put battery back yet just plug in power and switch on. If that doesn't work plug a monitor into the monitor port to check your lcd isn't faulty.
Feb 04, 2015 | Computers & Internet
It worked yesterday perfectly well. But today, i just switched on the UPS, then switched on the monitor and the UPS went off but the PC is still on. I then disconnected the Monitor, Now the UPS is on but...
Seems that the UPS has failed and so cut off power to the monitor. So please check your connection once again. The PC and the monitor must be given to the UPS and if the PC stays ON then the monitor must get power. So connect them to direct power to confirm if there is a fault, if so the power supply section would have failed.
now check on the UPS , check the battery on the UPS, is low it can disconnect. If so replace. Other wise the driver MOSFETS could have failed or a possible fault in the mother board.
Jul 29, 2011 | Acer AL1717 17" LCD Monitor
Computer monitor don't work at all.
So basically your monitor's power supply system died.
Nothing much a non-technician could do about it.
Get it repaired, if under warranty, get a replacement before the coverage duration expires.
Jun 07, 2010 | Computers & Internet
It turns on then immediatly goes black
hi,
check the power supply to the monitor...
the problem here is a corrupted BIOS you can correct it by booting the system with default settings...
if you are not getting any display then you can try the following
it should be blinking, the lights on the monitor... the cpu is working (all fans running)
then switch off the system...
remove the cover of the CPU on the motherboard there is a small battery called CMOS battery take out the battery after a minute later put it back...
it should fix it....
please give a vote if it helps
Mar 13, 2010 | Computers & Internet
On off switch seems not to work. both greenlight
yes you can fix it on your on.., just remove the battery on your motherboard and put it back
Jan 15, 2010 | HP Pavilion 8650C PC Desktop
DV8309 power up problem: blue lights on for few seconds then off
The inverter inside the lcd panel is most likely your problem. Try removing the whole lcd screen from the laptop if you are capable and run it with the external screen to confirm. leave the lcd switch off (this lcd switch above the power button turns the lcd inverter on and off)
Jun 19, 2009 | HP Computers & Internet
Acer laptop monitor backlight is not working
there will be power plan settings in the control panel... you'll have to modify it to have bright backlight even while working with battery...
Nov 07, 2008 | Computers & Internet
Acer Aspire One A150-1049 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
