Question about Kitchen Appliances - Others
Night Light/sochet removal
We received a Hampton Bay Floor Lamp (6 feet plus tall) model number 648-785. The shade is glass and shows up sort of up side down from a traditional lamp shade. Just beneath the glass shade is an LED night light encased in plastic. The first night the lamp and night light work fine. We moved the lamp and lost the night light. I called the maker of the lamp and was sent a light socket that would fit a traditional lamp bell/shade type of light.The socket and two way switch is encased in black plastic. It will start to unscrew with the cord turning inside the lamp but will only go so far. It is possible that it is the two switch not switching power to the lower night light, I don't know. I do not know how to get the socket from the lamp or to get at the lower LED light?
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
SOURCE: No Light from projector (worked previously)
theres prob something wrong wif the bulb
Posted on Dec 20, 2007
SOURCE: Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Posted on May 22, 2008
SOURCE: Plug sockets only failing
The age of the electric wiring could be an issue. I suspect a bad or loose connection at the recepticals. If appliance plug- in results in a loose connection,( IE: Plug falls out ). Replace the duplex recepticals as needed. Also check wiring connections to be sure they are tight.
Posted on Nov 27, 2008
Blue Dog
  • 75 Answers
SOURCE: Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Posted on Dec 22, 2008
I broke one of my 4 glass shades for my ceiling fan, how can I get a replacement?
Since, "Hampton Bay" is the house brand for Home Depot, your best bet is to start there. Getting an exact replacement will depend on how old your Hampton Bay Ceiling Fan is. Some glass shades and/or globes are discontinued after a few years, as the trends in shades change.
Hope this helped you.
Jun 28, 2011 | Hampton Bay Heating & Cooling
Need to order a cobalt blue glass shade for my Cameron II Fan Plus, who can I contact for assistance?
Contact home depot. They sell hampton bay and should be able to order you a shade if it is still available.
Sep 28, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
Hello there:
here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
best regards michael
  1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
  2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
  3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
  4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
  5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
  6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
lamp
Sep 24, 2009 | Electrical Supplies
We have a light kit on the hampton bay tahiti breeze ceiling fan and the glass shade is broken. how can we get another glass shade? please respond to djhampton@charter.net
Home Depot should stock them. If not, you should be able to order it online from them. Hampton Bay make fans exclusively for Home Depot.
May 18, 2009 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Light bulb burned out in ceiling fan
THE FAN IS ACTUALLY A WINWARD II BY HAMPTON BAY. ACCORDING TO INSTRUCTION MANUAL YOU TURN THE GLASS BOWL COVERING THE LIGHT ASSEMBLY UNTIL IT MAKES CONTACT WITH A COUPLE OF GROOVES IN THE RIM AND THE GLASS ASSEMBLY SHOULD RELEASE. I DID NOT RECEIVE ANY HELP FROM "FIXYA" BUT MAYBE THIS INFO WILL HELP SOMEONE ELSE WITH THE SAME PROBLEM. THE MODEL # OF THE HAMPTON BAY FAN WAS 523 342. (I FOUND MY INSTRUCTION MANUAL AND THIS IS WHERE I GOT MY INFO)
Mar 27, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton bay glass shade broke model no. 640-658
good luck cutrite , Hampton Bays importer King of Fans in Fl prob wont even know what your talking about they don't speak English very good. If you speak Chinese you might have a chance but if the part is over a year old..'forget about it' as we would say... they don't stock old parts (over a year) and everything is manufactured in China. Try a local lighting store you'll save yourself a lot of aggravation. And don't patronize Hampton Bay it only encourages them to push garbage on us all.
Feb 23, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Glass Shade for Fan Model 754332
You may want to check a local lighting store. They specialize in light fixtures and have numerous books to order from and a lot of expertise (usually, at least more than the high school kid at home depot). Hampton Bay is popular fan brand so I don't think they'll have much trouble.
Jan 24, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Torchiere with reading lamp(brushed nickel finish)
Did your fan come with some little round things with three silver metal pieces on them? With some of these fans, you have to hold the glass shades in place, then place one of these round things (sorry, I don't know what they're called) over the bulb holder inside, and screw them down until they're tight against the shade. Or you may have the kind of light kit where there are three screws on the end of the arms where the glass shades go. Just unscrew these a little bit more so your glass can fit, then retighten each one. This is what holds the glass shades in place. Good luck!
Sep 24, 2007 | Hampton Bay 24002 Ceiling Fan
Kitchen Appliances - Others Logo
74 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
