Question about Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum
My dyson DC16 constantly shuts off even when battery is fully charged. I cleaned the filters to see if that was the problem. It only runs for a few seconds before it shuts off. It will run intermittently for about 10 minutes before dying completely. Please advise
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
Hi its Darran at Dyson.
From your description of the problem, it sounds as though there is a problem with the battery.
Your DC16 will have been supplied with a 2 year guarantee. If it still within this period, please contact our Helpline on 0800 298 0298. However if your machine is no longer covered, a replacement battery can be purchased via our website at www.dyson.co.uk/store.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
I do not have a solution to the short run, and I have run into the same problem with my Dyson. I purchased a replacement battery which solved the problem for 1-1/2 years, then it reappeared. Another new battery solved it. I now have realized that the battery is always charging while in the wall storage holder, and being a Li-ion, they do not like that. When I use the vacuum, I am now putting it back in the charger, and letting it charge until all 3 lights are on, and then I put a business card where the contacts for charging are at the top of where the charger meets the vacuum, and when correctly placed, the lights go out, indicating that I have interrupted the circuit. I have put the date on the battery, and will see if this extends the life of the battery.
Posted on Aug 11, 2012
My dyson shuts off after just a few seconds of run time.
Make sure the charger is operating. Then if it is, look at a failed battery.
Jan 13, 2015 | Dyson DC16 Root 6 Bagless Handheld...
When is the DC16 red light supposed to change to green?
You can see the manual for the DC16 here: (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc16_uk_manual_cb_120710%20pdf.pdf )
Following the troubleshooting manual on page 6, fully charging the battery takes about 3 hours, for a run time of 6 minutes, so I'm not sure where 10 minutes comes from. The battery ships partially charged and was supposed to have been charged 3+ hours before a first use to get a full cleaning span.
It's also noted that you can get red lights if the temperature is out of an optimal range, and if the filter is not seated properly, so these would be things to check as well.
On the general checking list - look at the contacts for the battery and for the charger, make sure nothing is bent or corroded. Corrosion can be generally treated with use of some fine sandpaper or steel wool - be sure to blow the area clear of any steel wool fibers if you go that route. A better electrical contact sometimes will allow charging to get above a threshold voltage that will let the 'I'm charged' light turn green.
Good Luck! :-)
Jul 20, 2014 | Dyson DC16 Root 6 Bagless Handheld...
DC16 what else can be the reason?
We are sorry to hear you are continuing to have difficulty with your DC16. We would appreciate the opportunity to trouble shoot with you over the phone. Please contact our Helpline at 1-866-693-9766 US or 0800 298 0298 UK so we can help.
Best wishes,
Jessica
Feb 29, 2012 | Dyson DC16 Root 6 Bagless Handheld...
My dyson dc16 shuts off after 10 seconds its charged overnight but no good filters are clean but nothing I used it about 25 times a year .the batteries cost to much to replace for this expensive vac
I'm sorry to hear you're having difficulties with your DC16. It's probably best if you get in touch with us directly, as we'll be able to run through some troubleshooting steps over the phone with you to establish the cause of this issue. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
We'll look forward to helping you resolve this issue.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 13, 2012 | Dyson DC16 Root 6 Bagless Handheld...
Red light flashing constantly on dc16 when on charge, used to just stay permantly red without flashing until it went green when charged up.
I had a similar problem when I bought an after market 2Ah battery. Would stay solid red for a few seconds then flash red. I believe my problem was that the battery had gone into "sleep mode" I.e. it was discharged to the point that it "sleeps" in order to protect itself. So......I simply attached a domestic DC multi adapter to the terminals on the battery that are marked + and - (the 2 outside terminals on a DC16 Dyson battery). Switched on the DC adapter for around 10mins and this was enough to "wake" the battery. It now charges as normal attached to the DC16 in the Dyson charge mount.
For a pretty in depth article on lithium battery sleep have a look at this:
http://batteryuniversity.com/learn/article/low_voltage_cut_off
Oct 29, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My dyson dc16 is not holding a charge.. maybe I need to replace battery
If you call our Helpline they will be able to run through some simple checks to detemine the cause of this issue.
Please call 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Apr 09, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My DC 16 will only run for a second each trigger pull. The battery is fully charged, it has plenty of suction, just wont run for more than a second. I cleaned the filters.
I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
Oct 25, 2009 | Dyson DC16 Root 6 Bagless Handheld...
I have the same problem as steve967 The dyson dc16 is fully charged, runs well for 5-10 seconds and shuts down. I wait for a second or 2 and it runs again for 5-10 seconds. This will continue for...
Dear Michael_Stad,
I am going to sound like a broken record but here is my same answer to another person with the same problem.
I have I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
Oct 23, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum Logo
3,639 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
