Question about Canon CLC 1120 Color Copier
Canon error E079
E079 is in effect a drum fault. If you tell me your location I will find the price for a drumkit in your area
  • 86 Answers
E079 = tranfer drum cleaner does not engage or return to home position (ps9) first check the sensor ps9 and check the moter that operates the cam that engages the TRANSFER DRUM CLEANER. if you nead to know more please get back to me i am in the uk 00447764303923
Thank You
Posted on Feb 19, 2008
Hi I have a canon IR2570ci which is showing error code E000020-0290 can anyone tell me what the fault is and if a part needs replacing ?
Go into service mode and check under misc. It will give you reading for drum life Canon call it % but its not exact ... I would not let this exide 250 as drums start to drop toner and cause transfer belt slippage causing registration problems .. Mag is the most troublesome drum . (%)count carries reading with it and resets to 1 when you install a new drum .. New software has helped drum life issues but seems to double reading on a once off on drums installed during flashing .. Good Luck but if this doesn't work then it might be that you have a fuser heating error, which is either caused by a faulty temperature sensor, or the related circuit or possibly a blown heater element.
The copier will lock itself out, and will need to be reset by a technician, after it has had the cause of the fault cleared, this is a safety condition. It is to prevent runaway heating possibly causing a fire.
You will need a technician to fix this
Aug 18, 2013 | Canon PIXMA Office Equipment & Supplies
Have you tried to reset? maybe you can reset first meanwhile I will be looking for further solution
Feb 18, 2008 | Canon CLC 1120 Color Copier
The transfer drum cleaner HP
sensor (PS59) is faulty.
• The transfer locking driver PCB is
• The DC driver PCB is faulty.
• The CPU PCB is faulty.
0000 The transfer drum cleaner HP
sensor does not go '1' when
the transfer drum cleaner
locking motor has been kept
on for a specific period of
0001 The transfer drum cleaner HP
sensor does not go '0' when
Jun 20, 2010 | Canon CLC 1120 Color Copier
I have a canon imagerunner 1630 had a paper jam and had to pull drum to get it out, now can not get it back in correctly, display reads check toner/drum crg
Before reinstalling the drum make sure the Developer unit is correctly attached to the drum unit. The two clips ( Blue slides on top ) keep the two items together. Canon had two screws that were to added make sure the two stay together when removing the drum. Anyway make sure the drum is squarely installed with you insuring the rear is pushed all the way down. The sensor is located below drum near the entrance to the fuser. Good Luck
Apr 06, 2009 | Canon imageRUNNER 1630 Copier
My other half bought me a wii drumkit for my birthday today but can't get it to sync with my console. She was unaware that it is not a Nintendo make but a Harmonix although it is licensed by Nintendo. Can...
wll everthing is licensed by nintendo that is made for the aight? make sure ur wii remote is working and put ur wii remote in the drumkit . . . and if it still aint workin take the wii remote out and re sink it . . like press the two little red buttons . . the one on the wii and on the remot and if it still dont work then sorry due idk wut to tell u . . . hopefully i helped -eli . . . . . the coolest kid on da web
Mar 15, 2009 | Nintendo Rock Band for Wii
E079 code
all the 70 codes have to do with the transfer sheet unit ... either the sensors in it or the lift mechanisms motors etc unless your a tech this is probably over your head
Dec 10, 2008 | Canon CLC 1150 Color Copier
Error E079 Am using in canon 1180 Printer
E079 is the transfer lift clutch unit int the rear of the copier. You have to remove the unit and look for a broken cam & or pin that goes in the cam and clean both sensors and flags in that unit and make sure it is sping freely. The unit ingages the transfer cleaning unit. Good Luck.
Nov 06, 2008 | Canon CLC 1120 Color Copier
ERROR E079 0000
E079 basically means that the home position of the outside heating roller (engagement) is not detected, i think changing the position of the roller or getting it aligned should fix this problem. :)
Nov 06, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Error E079 0000
E0790000 means that roller (engagement) is not detected, try aligning the roller. if you have the owners manuel or CD Rom. it should show you how to align it.
If you have drum cartridge error you need to change the drumkit
Apr 21, 2008 | Office Equipment & Supplies
Canon CLC 1120 Color Copier Logo
208 people viewed this question
old marine
old marine
