Question about Bissell 3576 CleanView II Bagless Upright Vacuum
My vacuum tools have very weak suction. - Bissell 3576 CleanView II Bagless Upright Vacuum
There is a foam ring filter in the bottom of the canister that collects the dirt. It screws off of the bottom on the canister. Take outside and shake it out. It fixed our suction problem.
Posted on Apr 03, 2010
  • 10,865 Answers
Hello. You definitely have a partial blockage in your vacuum. Use another vacuum to **** the debris out of the hose, ideally a shop vac because they have fabulous suction. Regards, Joe
Posted on Jan 31, 2010
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
Weak suction
if you've changed filters and checked for blockages it may need a new suction fan ,,you can download the diagram off the link below
http://www.ereplacementparts.com/black-and-decker-phv1800-dustbuster-parts-c-4167_8887_8897.html
Mar 13, 2013 | Black & Decker PHV1810 Bagless Handheld...
Uv200 very weak suction
is there a blockage in the inlet pipe ???
Jul 12, 2012 | Black & Decker UV200 Wet/Dry Vacuum
Weak suction shop vac
Is the tank filled completely with dirt? When was the filter last replaced or cleaned?
May 15, 2012 | Vacuums
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Wertheim vacuum cleaner 2000 does not seem to be having enough suction
If you are sure the is no leaks on suction line, please check and clean the filter. The common problem on weak suction vacuum cleaner are leaks and filter clog up.
Regards
Jun 18, 2011 | Vacuums
What would cause the suction to be weak?
It sounds as though there is something stuck in the hose or outlet from the motor to the hose.
May 03, 2010 | Electrolux Vacuums
Is there a switch to turn-off the tools so that
On the Hoover U6311-900 there is no switch that turns off the suction to the tool hose. That hose is attached to the head of the vacuum on the side via a spring loaded "door". Just twist the hose to remove it, the door will close and you will have full suction again.
Apr 06, 2010 | Hoover U6311-930 Power Drive Bagged...
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
Feb 16, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Poor suction
Either you have clogged filters, or the motor is weak, you could check the carbon brushes, otherwise replace the motor.
Mar 28, 2008 | Vacuums
Bissell 3576 CleanView II Bagless Upright Vacuum Logo
297 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
