Question about Delphi Roady XT XM Radio Receiver
I don't know why my receiver doesn't stay on the channel when the power is off in the car. The receiver goes back to channel one most of the times when the power has been left off overnight. Is this normal?
  • 12,061 Answers
Yes this is most likely the default settings... when power is removed, perhaps wire it to an always on point?
Posted on Feb 01, 2010
Does not switch on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
Jan 18, 2013 | Yamaha RX-595 Receiver
Yamaha RX-V595 receiver won't stay on
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
I have 2 channel worth of wires i dont know what goes where
If you don,t no where only 4 speaker wires hookup to Get some one to help you that has done it before end noe,s what in the hell there doing, That you don,t fry it,
Dec 06, 2012 | Audio Players & Recorders
It crashes but still plays and can't turn channel over either with remote or the reciver, we have turned it off and back on again numerus of times we have also taken all the leads out the bk of it and
I have same problem today. Formatted my hard drive too. Now I believe it is an error in data sent for the channel listings. All we can do is wait.
Dec 14, 2011 | Humax Televison & Video
Can I plug a PC into one of the Onkyo HDMI ports? (TX-SR605)
Mike, I would agree. ANY device that either IS or emulates any hi-fi A/V device should work just fine assuming it doesn't deviate from the hardware standards of the 'real' hardware. Your Media PC is just another digital source as far as the receiver knows. Manuals don't mention everything because it is assumed that we know we can substitute compatible devices among the various in/outputs.
However, my own practice is to run every signal directly to the best device that enhances or uses it. NO VIDEO to my AVR (it goes directly to my monitor); NO HIGH-END AUDIO to the TV (it goes directly to my receiver). NO EXCESSIVE CABLES. NO PROBLEMS WITH UNNECESSARY CONNECTIONS. NO CORRUPTION OF ANY THE SIGNAL.
My PC's soundcard feeds both digital and analog audio inputs on my receiver so I have the flexibility of manipulating it in the analog domain for re-recording or just listening.
Nov 10, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
I have not received a diagram of my stylus wiring. none of the sites that was recommended have helped. do you know the purpose of each color of the four wires?
One is earth for the right, one is earth for the left, one is right channel and the other is left.
You don't need to know the colours to find the left and right channels. Just connect the turntable to the amp switch on. Then with your finger touch each wire one at a time. One will buzz on the left the other will buzz on the right. You might even get a slight buzz from the two earths.
The cartridge might have the left or right channels marked so you can connect them, but if it doesn't just connect the left to one side and the right to the other, then do the same with the earths. try it out, if the channels are the wrong way round change them, if the sound doesn't sound right change them again and again till it sounds right. You won't damage the amp or cartridge from doing this. Unless it's some kind of static effected cartridge!
Jul 30, 2011 | Audio Players & Recorders
My connext 4600 Turbo quiets receiving and getting out. Power is on, radio is lit up, might stay on for 30 min.- 1 hr. Squelch comes back on and starts getting out for up to 2 hrs. once power is cut off...
Well it does sound like a bad solder joint around your crystal,crystal is what gives you your freq.or channels.All I can do to help you without it being on my bench is to tell you to take the screws out the top of the radio,run the radio and when it quits lightly push on the top of the radio and see if that helps,if so it is a bad joint just find a cb shop that will take the time to find it.These are great radio well worth fixing.
Jun 04, 2011 | Connex 4600 Base CB Radio
I just picked up a 99 china cobra ltd st. Tx works on all channels, but no Rx on channels 1-19. Any help pointing me in the right direction would be greatly appreciated.
somebody tampered with internal adjustors seems to me. you can take a screw driver and turn off receive for so many channels but crank it for higher band. It was probably locked on a upper channel for a Friendly chat station say Channel #28. Where they stayed and talked on 1 channel all time. Could be that. Maybe its got broke wires or board on that other set of channels or parts fried, chip bad etc. Get it checked out at CB shop. if you have any knowledge, turn IF to receive and crank up receive inside radio. If don't know anything take to shop..sounds like simple fix to me.
Feb 18, 2011 | Cobra 29 LTD CB Radio
The power light blinks red! it can't turn On!
"If your 8002/7002 goes into protective mode (red power light flashing at two times per second) the receiver will not operate until it is reset. First try the reset procedure on the bottom right corner of page 81 in the manual.
If that doesn't work, press and hold the following three buttons on the front panel until the unit resets:
Pure Direct
7.1 Ch input
Clear
This latter procedure is not in the manual and I can't fathom why, as it can save the inconvenience of a trip to the service center."
Feb 03, 2011 | Marantz SR8002 7.1 Channels Receiver
Delphi Roady XT XM Radio Receiver Logo
117 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
