Question about Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid LCD Green Screen
37" Polaroid LCD - Connecting cableTV signal via HDMI results in Green Screen and "not support" message.
  • 1,476 Answers
Sounds like you need a new control board. Check www.partstore.com They should have it at a good price. Let me know how this works out.
hardrocko
Posted on Jan 31, 2010
No signal via HDMI
check the device manager on the pc to see if the hdmi is working properly. maybe it has no driver
Mar 12, 2014 | JVC JLC37BC3002 - 37 LCD 60Hz 1080P
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
My 3 years old polaroid TV , hasn't hight definition , three months ago, we take off the cable system and connected to a regular antenna , with the cable it gave us a very good sight , but now ...
Hi
High definition [HDMI] is a format used in tranmitting signals with cable connection. Transmissions are of analogue, and so the set will recogonize it and will chanve to it automatically when you connect the extrnal antenna. There is no way to chage an analogue signal to digital within the Tv itsef. It will display the signal as it is. Definition of analoge signals will be very less than [HDMI]. OK.
Jul 10, 2011 | Polaroid FLM-3734B 37 in. LCD HDTV
I have a Polaroid TLX-04240B It comes on and Displays the Polaroid logo, then it goes to a black screen with the HDMI1 input box on the top right hand corner. THis box eventually disappears, leaving me...
Buy another HDMI cable.Try another HDMI cable with another HDMI hub on the tv port.If u still have the same problems,mean the whole main tv Tuner signal board have problems and the caused.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
May 19, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a Polaroid FLM-373B 37 " tv and I get a blue screen with "No Signal" in the top corner. Cant seem to get it to find a cable signal, dvd signal or anything. I have successfully...
That situation clearly indicates that no signal is coming to the set in its present setting. Have you checked to make sure that the tv's input is set on the right input setting. Mine always defaults to "Antenna" which drives me nuts cause I get that big blue screen with "no signal". It seems to do that at the slightest provocation, too. After 5 years, I still have to think twice before checking it. If that is not it, make sure that the cables are plugged in. If that doesn't fix it try another type of input such as HDMI or S video, composite, etc - one that you are not using. Don't forget to switch the input to it. Good luck!
Nov 06, 2010 | Polaroid FLM-3732 Television
I have sharp 37 inch LC-37D44U MY PS3 is not working with it it green lights keep blinking power light and OPC. BUT THE HDMi ports work beacause i checked it with other devices. so i dont know why its not...
Does this happen when you input certain signals to the HDMI2_bing.gif ports? Or all signals (e.g. 1080i, 720p, 1080p, etc.)? And which ports are affected - side HDMI, rear component, etc.?
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)... their first visit allowed my TV to accept signals in the rear HDMI ports (all signals worked well), but then I couldn't get a signal processed via the side HDMI port. At first, just 1080p would not display (caused the OPC/power green light blinking), and after a few days, any signal hitting that port would cause the error lights to come on. But as I said, eventually, a new side board resolved that issue.
Sep 11, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
Tv is out
Unfortunately, for this TV the solution is to put it out on the curb. This television is what my father used to call a "known carcinogen". Sorry you had / are having problems with it, but you are SO not alone.
Feb 27, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Hd tv
My HDMI has stopped working. I have had a technician from Dish network out to my house 3 times and they have replaced the receiver and the HDMI cable and were unable to get the set to work all I get is a blue screen and a message which reads no signal. I also cannot use mt set using 3 rca cables connected to the component input when set to 1080 I keep intermittenly get a black screen then a blue screeen and sometimes a no signal message. I have to watch the tv set to 720 on component 2 and it is the most stable in that setting. Please send help
Jul 06, 2008 | Protron PLTV-37 37 in. LCD Television
Polaroid FLM-3734B 37 in. LCD HDTV Logo
184 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
