Question about Onkyo DX-RD511 CD Player
Solve a jammed cd problem
Cd jammed and door won't open to retrieve it/them
  • 1,476 Answers
Usually if you remove the cover you can access the area where the CDs are. You may have to remove the cover from the drive also. Let me know how this works out.
hardrocko
Posted on Jan 31, 2010
Stuck Sony CDP-CX355 Carousel CD player - door won't open, just hums
Something must be jammed so a trip to a Technician will resolve that. This is one of the reason I never buy changers of any kind because over the years I have had to fix so many cartridge, platter and other changers that are all designed poorly enough to make the 90 day period but not last too much longer. The Sony ES models are the best but they were big money back then- I have a broken one in my shop now.
Jan 23, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cd player won't open and won't power off.
This means that something in the mechanism is jammed. It keeps on trying to correct for the misalignment- a service technician will need to see the unit.
Dec 08, 2012 | JVC XL-FZ258BK 5-Disc CD Changer
Door will not open
this product seems to be an audio CD player in use with a stereo system.
Have you tried inserting a paperclip (that has been straightened out) through the tiny hole available to manually coax the tray to come out. It will pop out just a little, but it will then be unlocked and be easy to bring out, displaying the entire CD.
If you have tried that, then.....
Take the cover off (the entire case) and inspect the area where the CD is. Many of these players have no metal encasement around the CD mechanism and one can see the inner workings. The CD may have gotten askew, or the mechanism jammed. Gently try to free things up.You should at least retrieve your CD.
Put the thing back together. Use a junk cd (keep the stereo amp off) and try to load and unload it. If that fails.... Time to get a new one.
Here's a suggestion for that. Most all DVD players handle cd's. Purchasing an inexpensive DVD player might be cheaper than finding a stereo component CD player. Just use the audio out.
Good luck
---Sam
Oct 04, 2012 | NAD C521 CD Player
Back passenger door won't open
if it won't open from the inside, it's your child lock in the door jam....
May 21, 2011 | Ford Escape Cars & Trucks
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
Paper is jammed righ below the scanner. Unable to retrieve the jammed paper.
hello.
on the adf you have a door that opens retrieve the paper and see if there is any things that jammed the paper.
May 08, 2011 | Canon Imagerunner 1025IF Grayscale Copier
Cdn-24 cd door wont open
Often the cause is a jammed CD or aa little belt that drives the carriage has failed or is slipping.
You need the OPEN the case to retrieve the CD if one is in there and check the mechanism does not have a problem. Some drives used to have a SMALL hole near the door that one would insert a straightened paper clip into straight to press a release... You might check for that.
Feb 25, 2011 | Numark CDn25 Professional DJ CD Player
A cd is jammed in the all-in=one drive it is in the wrong way how do I unjam it
there is a pin-hole switch in the wrong of the drive, that is designed to open the drive manually in case of loss of power, or if the drive door gets stuck. You can do the following to open it:
1. straighten out a paper clip, or small pin. you will use this to press the release.(note: make sure if you are using a pin, it isn't sharp! you want to open the drive- not puncture it)
2. locate the pinhole (usually below the drive door), and stick the pin/paper clip in there. keep pushing, and the drive door should pop open slightly.
3. using your hands, gently pull the door the rest of the way open, and retrieve your CD.
Hope this helps.
Jul 02, 2010 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
Cd won t eject from 2006 Ford Focus mp3 player Get eject error message How can I safely remove CD''
HI, either the deck assembly is jammed or, the load motor has failed. In this case, you will need to disassemble the entire set in order to retrieve this CD.
The actual loading deck(the part where the CD is located), is surrounded by a metal housing. the gear assembly is probably locked, due to this jam or failed load motor. This will also require a set of precision tools as well. if you find this a bit overwhelming, i suggest taking this unit to a local automotive audio shop. they can dissemble it and, retrieve the CD for a small price.
Jun 21, 2009 | Kenwood KDC-MP638U Car CD/ MP3 Player
Deneon UD M50 - Tray jam
It sounds like the cd tray has been forced shut and has been damaged when you got the CD's out. If it was me I would of unscrewed the casing and retrieved the CD's that way instead of trying to force the try open which I'm assuming you have done.
It could just be a simple matter of just slightly adjusting the internal CD mechanism so that it can open and close properly without jamming. The error message comes up because the tray cant eject properly. The worse case scenario is that the CD mechanisam would need to be replaced. Not a hard job for a service engineer, if you dont fancy taking the thing apart yourself then a service centre is your best bet.
Nov 01, 2008 | Denon D-M50S CD Shelf System
Onkyo DX-RD511 CD Player Logo
150 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
