Sony kv-xf25m30 trinitron clicks wont turn on
Sony kv-xf25m30 trinitron,
no picture or sound, constant clicking of relay and indicator light flashing once every second.
assuming power board is gone.
anything in particular on board??
should mention i'm an electronics engineer but have no diagnostic equip to test the circuit apart from multimeter, but can get caps/relays individually and replace.
  • 12,061 Answers
Yup sounds like a classic SMPS fault OK, probably the "Chopper" transistor? but could also be the controller, the best way is to get a new PSU, but check to see if PSU is OK without a "Load" if it is then it is NOT your PSU,and the fault is elsewhere and is shutting it down. Usually it is something drawing a lot of current.. often in the Horizontal section, but not always.. GL
Posted on Feb 01, 2010
My Sony Wega Trinitron KV-32HS20 does not tun on and the standby light flashes 4 times. I can hear the sound but no picture and the it turns off automatically after a few seconds.
This is a tip I got from a tech bulletin.
IC600 output pins 14, 15, 16, all have aprox 130v (all should be higher) until relay clicks
then they drop off. 200v line goes up to 50v, 135 goes up to 40v.
Checked D611 (135v rectifier) it was fine. Checked D615 (It's labeled D601 on the board)
it was shorted. (D615 is the 19v rectifier for the Audio B+) Removed D615 set power up
and has good picture with no sound.
Sep 08, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
Sony Trinitron KV 27
Please count the blinks and post that number. That is an internal diagnostic code that will indicate the problem circuit. From that I can give you probable repair parts and costs.
Thanks,
Dan
Dec 24, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-27FS100 No Picture
Check Horizontal Output Transistor, if found bad / short, replace it.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
