Question about GE Dishwashers
My control panel panel has the normal wash and heat dry buttons are lit and nothing else happens. it will not allow me to turn the machine on. the start reset button does not operate the dw
  • 105 Answers
Sounds like it is either a door switch problem or an electronic control problem. Best off to call a reliable service company such as Sears.
Posted on Jan 31, 2010
No sign of life to our 5 year old D/W except flashing "CLEAN" L.E.D.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
Apr 03, 2014 | Whirlpool GU2800XTV Dishwasher
Kenmore Ultra Wash Model 665.1388 problem the normal wash green light is on heated dry light is on and the start resume light is flashing but wont startup helpppp
see your instruction manual and go to the section troubleshooting and fix it.
if you do not have the i.manual download for free www.retrevo.com or www.fitness.manualsonline.com
see the diagram
God bless you
Jun 18, 2012 | Kenmore Dishwashers
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Maytag Quiet Series 300 Will not work at all, only the lock feature is lit.
I had the same problem. The lock button light was on, nothing happened when pressing start, cancel, etc. I also tried holding the heated dry button (lock) for 3 seconds and no luck UNTIL holding down for three seconds while also pressing the cancel button. I was then able to start cycle as normal.
Apr 18, 2008 | Dishwashers
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
76 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
