Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv turns on then shuts off by itself.
I just goth tv back from repair service for shutting off by itself after you turn it on. The power supply was replaced. When I got it home it worked for a couple of hours. I turned it on later and it came on blanket ot then shut off.
  • 1,476 Answers
The problem was probably not in the power supply. More likely the control board was the problem. Have the shop check that out. Obviously the board they replaced was not the problem. Let me know how this works out.
hardrocko
Posted on Jan 31, 2010
My Samsung TV HLS4288W shuts off by itself. When I turn it on it repeats with the same, shuts off. I have to repeat this process several times before the TV finally stays on.
There's a loose connection in the power supply of your television.Try to fix this problem.If you want to do the repair,just open the back cover of your TV and look the power supply.Try to resolder the board of the power supply and check the connector to power supply from the board supply.You can power on the televisions while the back cover is open to see that the power supply is working. Thanks!!
Aug 21, 2011 | Samsung Televison & Video
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV was on and shut off by itself. will not turn
Probably power supply, call Vizio for slow service
May 12, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 06, 2008 | Digimate DGL26 Television
Jvc av-48wp55 shutting off on its own
Is pix ok before shutdown?
If convergence is wildly misaligned then load may be shutting down power supply. Fix convergence and TV OK.
or
Poor solder connections on main chassis near FBTX and h drive. Needs expert solder work
easyab@hotmail.com
calgary
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
Jun 14, 2008 | JVC AV-48WP30 48" Rear Projection...
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
128 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
