Question about Philips CD 4453 Trio 1-Line Cordless Phone
Cd4454 Quad, one handset getting very hot
The rechargable batteries are getting very very hot. I have now swapped the batteries from another handset to see if it is the batteries or the phone that is at fault. Does this happen when the batteries are dying? We havn't had the phones a year yet! I am a little worried the phone may get so hot it starts a fire!
3 Suggested Answers
richa33
  • 71 Answers
SOURCE: new batteries for Philips Dect 225 phones
1.6V to 1.7V doesn't bother . Normally handset have voltage booster, DC to DC circuit to 3.3V for microprocessor. Even 2*1.7V =3.4V , still ok for microprocessor .
Posted on Jan 21, 2009
SOURCE: Philips Dect 215 phone continually bleeping.
Remove all handset batteries and leave for 10 minutes.
Unplug main cradle and reconnect after 30 Seconds.
Replace all handset batteries and place handsets back on cradles.
Posted on Oct 07, 2009
How can I get new batteries
Normally in the BT range the batteries are rechargable, hence the base charger, so do not use ordinary batteries. If the phones are not charging, go to boots or tesco and buy AAA rechargeables 2 per handset. Once replaced allow at least 6 hours charge before use. After that just carry on as normal.
Jul 23, 2014 | BT Freestyle 750 Digital Cordless Handsets
I have a uniden 5.8GHz cordless phone with 3 handsets. But now 2 of the handsets do not work. The base lights up to show it is charging and when I pick up the phone, the handset says...
You may have a problem with your battery. Usually the rechargeable battery goes bad on those units. Swap the battery from the working handset to one of the non working ones.
Dec 16, 2017 | Uniden 5.8GHz Cordless Phone
My phone isnt coming on but the base is on charge
More often than not, this is simply due to dead batteries - do you know how old the batteries in the handset are? if they are quite old it might be worthwhile replacing them with the correct type of batteries (please ensure they are the correct type otherwise you can cause a fire putting non-rechargable batteries in a rechargeable phone) as this usually fixes the issue.
One other question, has the handset been dropped lately? This is another usual problem for a handset to stop working so ask whoever uses it and hopefully you will get a truthful answer :)
thx, if this helps please rate :)
Jan 28, 2011 | Uniden Cordless Phone
Base on the 2 phones both keep flashing base. tried to swap them over, turned on and off, but nothing
try replacing the batteries. Sometimes the flashing is just because it's not charging them.
I believe the Siemens uses standard rechargable AA batteries?
Jun 11, 2010 | Siemens Gigaset 4200 Cordless Expansion...
Have 2000 dodge dakota quad cab air conditioner quits
When you recharged the vehicle did you have it vacuumed?
Apr 09, 2010 | 2000 Dodge Dakota Quad Cab
My handset reads Low Battery Charge Handset and i put it on the base and it wont charge how do i fix this?
Well.. You may not like my solution.. because I had the same problem with the same phone as you have and everything I did was not successful. WHY you ask??
Because it sounds to me that the rechargable battery itself is either defective, worn out \Or maybe the phone was dropped causing the battery damage, due to the sudden jolt when it hit the floor, as these rechargable batteries are not indistructable??)
I bet if you go toUNIDEN site or the electronic store and replace the rechargable battery, with a BT800/BP800 Battery Pack as what I had to get (but check make/model of the battery pack you already have installed in handset), your phone will continue to operate as if it was new again. I paid about $30- for my battery pack.
Feb 15, 2010 | Uniden DECT 6.0 Cordless Telephone...
While I'm talking, it starts to beep and then goes dead. I assume It's battery problems as the whole set gets hot while it recharges. Where/how do I replace the battery? Is it in the phone or in the base?...
The battery is in the phone, otherwise you would not be able to move around with it. The battery is probably at the bottom of the handset close to the place where electrical contacts are made (metallic prongs). Look on the back of the handset for a small depression like a thumbnail. By pressing on it with your thumb and pushing away from the body of the phone you should be able to move it.
Jan 28, 2010 | Panasonic KX-TG5210 Cordless Phone...
Uniden cordless handsets don't hold charge
Have you tried replacing the batterys with new rechargables? if not open up the back and replace old batterys with new ones, just see if it works with a normal non rechargable batterys if it does buy some new rechargable, other than that your base i.e. charger may be faulty most likely it is the batterys.
Jul 19, 2009 | Uniden Cordless Phone
It won't charge the rechargeable batteries anymore
I have the same problem , the only logical reason i could think of is that the charger connecting to the base station has malfunctioned .
Aug 30, 2008 | Philips VOIP8411B/37 IP Phone
Philips CD 4453 Trio 1-Line Cordless Phone Logo
67 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
