Question about GE Profile Harmony DPGT750EC Electric Dryer
Flawless for 18 months. Just started NOT heating. Filter is OK (front), but no air flow out the vent. No error messages on control panel. Would take off back if I could see how :) Any help appreciated !
  • michael517 Feb 01, 2010
    OK, turned out to be a RAT caught in the blower wheel. Would have been a lot easier if someone had told me that you DON'T take off the back, but the FRONT.
    Much easier, and DON'T forget : That blower NUT is a LEFT HAND thread !!!
Maytag electric dryer 2 yrs. old working OK today no not. Blowing cold air..
Posted on Jan 31, 2010
Need pitcure of vaccum lines on 1999 Ford Ranger v6 3.o air and heat blows only threw the defroster.
Item Part Number Description 1 18A318 Vacuum Control Motor-, Panel/Defrost Door 2 18A478 Panel/Defrost Door (Full Vacuum Position) 3 - Defrost Air Flow 4 - Side Window Demister Air Flow 5 18B545 Temperature Blend Door (Full Heat Position) 6 19860 A/C Evaporator Core 7 19A813 Air Inlet Duct Door (Full Vacuum Position) 8 - Outside Air Inlet 9 18A318 Vacuum Control Motor-, Air Inlet Duct Door 10 - Recirculated Air Inlet 11 18527 Blower Motor 12 19A566 A/C Vacuum Reservoir Tank and Bracket 13 - Vacuum from the Engine Intake Manifold 14 19B888 A/C-Heater Function Selector Switch 15 - Vacuum to the 4x4 Hub Solenoids 16 18495 Water Diverter Valve (Full Vacuum Position) 17 18476 Heater Core 18 18A559 Floor/Panel Door (Full Vacuum Position) 19 - Floor Air Flow 20 18A318 Vacuum Control Motor-, Floor/Panel Door 21 - Panel Vent Air Flow
Dec 09, 2016 | Ford Ranger Cars & Trucks
GE gas dryer DSXH47GGWW- starts fine and begins to heat up then shuts off with a message that the lint filter needs cleaned. The lint filter has been completely cleaned and vacumed inside, outside and...
With no lint anywhere around the dryer the thing to check if havent already is the venting itself to see if outside it is blowing and not restricted or blocked
The control is sensing poor air flow and throws up the "clean filter" when air flow is restricted all be it from the filter clogged, or blocked/restricted vent
Gene
Aug 25, 2011 | GE Dryers
Climate Control - Heat and cool work fine. Air flow is directed to defrost /floor. No indication (Sound or sight) that the vacuum diaphrams are being activated. The display on the dash matches the...
Does your vehicle have manual or automatic climate control ? You system is stuck in floor an defrost mode ?
03 mercury grand marquis hvac air flow .-13qahwfdndst2y1hypmr2cdq-4-0.gif Item Part Number Description 1 18A318 Vacuum control motor-floor/defrost door 2 - Defrost air flow 3 18A478 Floor/defrost door 4 18476 Heater core 5 19860 Evaporator core 6 19805 Blower motor 7 - Outside air inlet 8 19A813 Air inlet door 9 18A318 Vacuum control motor-air inlet door 10 - Recirculated air inlet 11 18B545 Temperature blend door 12 18A559 Panel door 13 - Panel air flow 14 18A318 Vacuum control motor-panel door 15 - Floor air flow 16 - Vacuum from the engine intake manifold 17 19A563 A/C vacuum check valve 18 19A566 Vacuum reservoir tank and bracket 19 19980 EATC control
Pull the control panel an check for vacuum
vacuum lines hvac 03 grand marquis-13qahwfdndst2y1hypmr2cdq-4-2.gif Item Part Number Description 1 White Air inlet door 2 Yellow Floor/defrost door 3 Red Floor door 4 Blue Panel door 5 Black Source vacuum 6 - Not used
VACUUM APPLICATIONS CHART-ELECTRONIC AUTOMATIC TEMPERATURE CONTROL Switch Port Vacuum Harness Hose Color Func- tion Manual Override Selector Buttons OFF MAX A/C NORM A/C VENT FLOOR FLOOR/ DEF DEF 1 White Air inlet 2 Yellow Floor/ panel (partial) 3 Red Full floor 4 Blue Panel 5 Black
Source
May 21, 2017 | 2003 Mercury Grand Marquis
I have a carrier lp gas furance 9200 with error code 34 can you help me thanks.it will not start up to make heat
If you remove the front panel, you will find a diagnostic error code chart that will help you diagnose the issue. Usually it is either a pressure switch code or a high limit code. Check your air filter, condensate hoses for blockage, check the venting for any sags or water trapped and any debris blocking the exhaust or air intake vents.
Mar 29, 2011 | Carrier Heating & Cooling
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
Whirlpool Cabrio Dryer 3 months old
"AF" is a restricted air flow condition. You say you've only had your dryer for 3 months, but have you ever cleaned the ducting? You need to check the lint screen after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know.
Jan 27, 2008 | Whirlpool GEW9250 Electric Dryer
My candy civ60 dryer dose not heat
hi i too had that problem,when an engineer looked at it the thermostat,element were ok,he suggested that there was a blockage in the air flow,i took the whole thing apart ( i had nothing to lose ) cleaned it with a hoover very carefully then with a clean dry paintbrush,there is vents underneath the dryer if these get blocked the dryer blows cold air, its a saftey measure so that the fluff dosent catch fire ! i hope this helps,mine has run ok for 3 months now.
Dec 28, 2006 | Candy CIV60 Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
129 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
