Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Beater turning very slow motor sounds labored
    New Friend:
  • 87 Answers
This is often a symptom of worn brushes. The brushes are under the two (normally black) plastic caps on the sides of the head. New ones look like the one shown on this page.
Posted on Feb 01, 2010
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
KitchenAid KSM50P mixer sporadically stops working
Hi, This sounds like you have an issue with the planetary gear system. The mixer has a plastic worm gear inside the planetary that is prone to wear and failure. I would bet that it needs replaceing.
Mar 13, 2010 | KitchenAid Food Mixers
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I have a Kitchenaid Professional 5 Plus Mixer beaters won't turn
It sounds like it has been overloaded and the worm gear has been stripped. You will need to take the head apart to confirm this.
Jun 24, 2009 | KitchenAid K45SS Classic Stand Mixer
Beaters don't turn
You should try to replace the beater turners or try to fix the problem that causes the beater turners not to work.
May 01, 2008 | Sunbeam Heritage 2346 Stand Mixer
Beater does not turn
It sounds like the nylon gear is stripped out. It is a rather easy to replace and also inexpensive. A gentlemen posted a step by step site to replace the gear. The link is http://www.neilcrockett.com/mixer.htm
Good Luck
Sep 13, 2007 | KitchenAid 32685 Mixer
Leaking oil
thats the planetary seal thats leaking.the seal is cheap its the labor that may be costly.is it just a nuisance leak or a lot?you dont want any oil to get in your mix.
Aug 16, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Just get clicking sound . . . beaters don't move
you snapped one of the drive gears. Your gonna have to get someone whos mechanicly inclined to take apart the drive motor assy and see whats broke. You should be able to get the parts at http://www.repairclinic.com good luck
Jul 15, 2006 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
170 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
