Question about Sony MHC-EC50 Shelf System
Every time i tab the button which should turn its power on, it tu
Hi
my stereo got a problem, every time i tab the button which should turn its power on, it turns first on regular but after 3 seconds, it gives a click and powers off, pls. help me! thank you
  • 1,476 Answers
Sounds like you have a short in the unit. You will have to take it apart and check the power supply for bad semis. My best guess is that your problem lies in the power supply. Let me know how this works out.
hardrocko
Posted on Jan 31, 2010
My jenesen uv8020 wont power up i hit the rest buton and the blue buton lights turn on but turn right back off i replaced my front broken screen it powered up it worked for a 7 months when i would tu
I need more info. Did you check the ground wire to make sure you have a good ground? Some installers try to rely on the antenna for a ground when hooking it up due to laziness and it will eventually burn the stereo out from low voltage, or, you could have amps that are killing the battery enough to drop the voltage down and it's killing the stereo. I have also seen ground loops kill stereos, but, I need a bit clearer info as to exactly whats happening to answer the question.
Nov 29, 2014 | Jensen Car Audio & Video
How do you reset the system.
To reset the component Hi-Fi stereo system to factory settings.
  1. On the stereo system, on DECK B , press and hold the STOP button.
  2. While holding the STOP button, press and hold the TUNER ENTER button.
  3. While holding the STOP button and TUNER ENTER button, press the POWER button.
  4. Unplug the power cord from the electrical wall outlet.
  5. Plug the power cord back into the electrical wall outlet.
  6. Turn on the stereo system.
Sep 30, 2014 | Sony STR-DA3000ES Receiver
Why won't my Delco stereo will not power on?
Hi Carol
Their are two possible thing that causes your stereo fail to be working.
1. Power supply terminal is not properly attached.
2. Busted electronic component inside the stereo.
Some stereo, when their is busted component inside, it wont turn on. So you better have it check to authorize technician or by your self.
Sep 13, 2014 | Cars & Trucks
I forgot my password for my samsung galaxy tablet
hi ,
1st want to tell you that you have lost your data and all thing, but you have free your device from password.
do this steps
  • Make sure tab is turned off, Press and hold the Power button for about 10 seconds to turn it off.
  • Press and hold the "Volume Up" and "Power" buttons at the same time, when logo appears on the screen release the "Power" button and continue press the "Volume" button
  • When recovery screen appears use "Volume Up/Down" buttons to navigate and select "wipe data / Factory reset" by pressing the "Home" or "Power" button (Depends on Galaxy Tab model).
    its surly working 100%
    any thing else reply me
Nov 05, 2012 | Samsung Galaxy Tab Verizon 3G Android 7in...
Programming the cn101a timer
CN101A programmable weekly digital timer
Buttons
C = Master Clear, erases all program settings and current day/time.
C/R = Control/Reset, used to access programming mode and to clear individual programs.
You must press and hold this button for approximately 4 seconds to enter programming mode if there is a lower case "a" to the left of the time display. The system will revert back to active mode (with the lower case "a" to the left of the time display) after 30 seconds with no buttons pressed.
If this button is momentarily pressed while viewing a program, that program will be erased, but ONLY the On or Off program that is being viewed will be reset. The corresponding On or Off program in that cycle will NOT be reset.
Clock = In programming mode, this button is held depressed at the same time as one of the D+, H+, or M+ buttons to set the current day and time. When editing the programs, this button is used to exit when done.
P = Program select, each press will advance through the On and Off programs (presets). There are 16 On/Off cycles available (1 On, 1 Off, 2 On, 2 Off, ... 16 On, 16 Off).
D+ = Used to change the day when setting the time, or day(s) when changing a program.
When changing a program,
the following 15 different day combinations are available using the "D+" button.
MO; TU; WE; TH; FR; SA; SU; MO/WE/FR; TU/TH/SA; SA/SU; MO/TU/WE; TH/FR/SA; MO/TU/WE/TH/FR; MO/TU/WE/TH/FR/SA; MO/TU/WE/TH/FR/SA/SU.
H+ = used to change the hours when setting the time or a program.
M+ = used to change the minutes when setting the time or a program.
Manual = This button will cycle the output relay from AUTO to Manual OFF, back to AUTO, then to Manual ON, and finally back to AUTO. Programming mode must first be accessed using the C/R button to use the Manual feature. The manual On or Off settings will override all programs until switched back to AUTO.
There is a Lithium Ion battery which is intended to keep the clock going for up to 3 years during loss of external power, but the output relay will not work on internal battery power.
Jan 17, 2012 | Hardware & Accessories
I turn the stereo on and it turns off and then the power button starts blinking
i turn the stereo on and it turns off and then the power button starts blinking
Sep 04, 2010 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
Unit does not turn on or display time
do you mean a power surge, if so the surge may have overloaded the elctronics,=cooked ,so afraid is u/s
Jul 07, 2010 | Fisher SLIM-3010 Shelf System
My stereo is not coming on.. the time will illuminate when i press the display button and the lights behind the buttons will come on but will not turn on.. the cd will eject as well but thats it..
Sounds like the fuse for the switched power has blown. The stereo has two power inputs -- one unswitched, called "memory" because it lets the stereo remember your presets, and one switched, just called "power"
It should let you see the time, eject a CD, etc all when the car is turned off. Since the fuse for the main power line is blown, the stereo thinks the car is turned off all the time.
Feb 13, 2010 | JVC Car Audio & Video
Inactive standby option
>I saved myself from a lot of these problems. I set the power button on the front
>of my computer to put my PC into hibernation.
>This is how you do it:
>1. Go to the Control Panel
>2. Open the Power Options window
>3. If Hibernation isn't on, go to the "Hibernate" tab and turn it on.
>4. Once you have hibernation on, go to the "Advanced" tab.
>5. If your computer supports it, there should be a dropdown menu in the "Power buttons"
>area. From there you can make your computer perform a lot of power management functions
>including Standby and Hibernate.
[Reply or follow-up to this message]
Jul 10, 2008 | Microsoft Windows XP Professional
Technics sd-s2300 ampli su-g91
tu dois voire si tu as tout les cables entre sur le stereo
Feb 18, 2008 | Technics SA-AX540 Receiver
Sony MHC-EC50 Shelf System Logo
205 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
