Question about Whirlpool Freezers
Ice builup on back wall of top mount whirlpool freezer
I had a problem with my 14 yr old whirlpool ref. i ahd a large buildup of ice on the back waal of the top mount freezer and the food was starting to thaw. i cleaned the ice off and turned the temp down a bit this seems thave helped but its only been about 12 hours. i also cleaned the coils. ant ideas?
  • 401 Answers
It sounds like it is not defrosting. Could be the heater, terminator, or the defrost timer. There is still ice built up behind the wall and won't take long for it to stop working again.
Posted on Feb 14, 2010
Ice maker quit making ice
Does the food in the freezer freeze solid? Do you see any ice buildup on the back wall?
Nov 10, 2012 | Frigidaire FFHT2126LW 30" 20.6 cu. ft. Top...
Freezer compressor gets hot
Check behind and underneath for dust buildup, sounds like your compressor needs cleaned on the outside, the dust is causing it to overheat and retain condensation, hence the ice buildup. Easy thing to check, good luck.
Jul 02, 2017 | Frigidaire 19.53 cu. ft. Commercial...
I have a EV171NYMQ05 up rigtht Whirkpool Freezer Model. The upper half of the freezer is thawed out ( I do not hear the fan running) and the lower half is frozen. Where do I start?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 13, 2011 | Whirlpool 17 cu. ft. / 481 liter Upright...
The power went off and back on during a storm the other night. Now we noticed the freezer is not running. The display that usually shows the temp. setting was showing a y. I unplugged the freezer and...
NOTE: This
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Leo Ponder
imufo2
NOTE: This
Leo Ponder
imufo2
Aug 06, 2011 | Frigidaire FFU17F5H Upright Freezer
Coil in top of freezer and top shelf in freezer have very large buildup of ice, melted it out but it soon froze back over
Good day,
I assume this is a conventional freezer, not a frost free model.
That condition is caused either by a loss of refrigerant or an internal restriction in the sealed system.
Both are, I'm afraid terminal, unless the machine is under 5 years of age, in which case it would be covered by factory warranty.
Sep 05, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sometimes water comes out everywhere all over the floorand on the inside, now everything freezes inside the firdge
behind the freezer inner wall is a tube that leads down to a pan under your refrigerator it is blocked: remove the wall; remove the ice buildup on the evaporator coils then using a funnel pour hot water through the tube to the pan. be sure to empty the pan when you are done
Sep 05, 2009 | Whirlpool Freezers
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
Freezer temp
Was the condenser fan back there running. It should be when the compressor is.
Is the fan in the freezer running. Check for ice buildup on the back wall and behind the back wall cover on the evaporator coil. Heavy ice here would be defrost problem.
Jul 12, 2009 | Freezers
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Freezer not getting cold enough
I think your system has a leak and has lost the refrigerant charge.
The only way to check is by accessing the sealed system. Most systems are covered for five years on the compressor. Contact the place of purchase and give them your indications for your problem.
Jul 06, 2008 | Freezers
Freezers Logo
100 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
