Question about Acer Aspire 5050 Notebook
Acer goes blank
My acer aspire 5050 starts up well but goes blank just before password logging. but works fine in safe mode
  • 1 more comment
  • prestancebra Feb 01, 2010
    i tried to restore it nothing happened, and i dont have the c.d that came with the laptop
  • prestancebra Feb 18, 2010
    by taking these steps. is my memory going to be completly earesd?
  • prestancebra Feb 19, 2010
    ok. thanks. im going to countinue trying them.
  • 728 Answers
What I would try to do, is first in safe mode go to your system restore, and restore the system back to a date prior to when this happened. If system restore for some reason isn't turned on, or faults when it restores, then I would use your original install or systems repair disk that came with the computer and restore windows back that way. If neither of those options are available Post back and let me know, and we can try some other longer processes.
Thanks Mark
Posted on Jan 31, 2010
  • Mark Taylor
    Mark Taylor Feb 01, 2010
    Ok, then you can use the System Information utility (accessible by opening the Start menu and clicking Programs [All Programs in Vista], Accessories, and System Tools), to help you determine device conflicts and find out more about the technical details of your PC's configuration. Expand the Hardware Resources menu in the left pane of the System Information window and click the Conflicts/Sharing item. Here, you'll see a list of shared resources and a notification if the sharing is causing a system conflict. Check through the various categories to see what might be the problem.
    You also can access the System Configuration Utility. In WinXP, click Start and Run, type sysedit in the Open field, and press ENTER. In Vista, click Start and then type sysedit into the Start Search bar. Press ENTER or click sysedit.exe when it appears in the Programs menu.
    This tool opens the four configuration files (Autoexec.bat, Config.sys, System.ini, and Win.ini) in a small text editor. If you have experience with these files, you'll be able to alter system, program, and driver settings from within them. If these files are new to you, the trick to using them is to locate items that reference programs or drivers you know are causing problems, deleting the offending items, and saving the file. But before you change anything, make a copy of the originals for later retrieval if necessary.
    You can also open your msconfig Utility, which In WinXP, click Start and Run, type msconfig in the Open field, and press ENTER. In Vista, click Start and then type msconfig into the Start Search bar. Press ENTER or click msconfig.exe when it appears in the Programs menu. This open up to selective ways to start the computer, it reviews the drivers for the system, windows booting ini configurations. Again, if you don't have experience in these files, make a backup copy prior to making any changes. Next look at your services tab and see what services you can disable to help get windows to start normailly, As well as the Startup tab, some of these things you don't need to have startup could be causing the problem, And lastly, windows gives you a lot of other tools to help under the tools tab, along with explainations of whet they do.
    If all of these procedures fail to solve your problems, it's time to work directly with your hardware via the Device Manager while in Safe Mode. In WinMe and Win98, right-click My Computer, select Properties, and choose the Device Manager tab. In WinXP open the Start menu, click Control Panel, click Performance And Maintenance, click System, choose the Hardware tab, and click the Device Manager button. In Vista, click Start, Control Panel, Device Manager.
    From the Device Manager, locate one device you suspect might be causing trouble, such as a device you recently installed, and right-click it and select Properties. Disable the device using the Device Usage drop-down menu or deselecting the appropriate checkbox from the Device Usage area and restart your computer into Normal mode. If your system now works properly, you've discovered the problem. You can shut down your system, remove the hardware from your computer, and call the manufacturer to report the problem.
    If your computer still won't start (or won't start properly), the two probable causes are a hardware conflict or a Registry problem. Before trying to correct a suspected hardware conflict, you can check your Registry for problems it might be encountering.
    Restart your system, enter the Startup Menu, and choose Command Prompt Only (or Safe Mode With Command Prompt in WinXP/Vista). You can accomplish this in WinMe, which has no such menu item, by launching from your Windows startup disk. Then, at the command prompt, type scanreg and press ENTER. The Windows Registry Checker tool will appear on-screen and try to locate and repair invalid entries. It draws its information from backups of system files and the Registry settings it creates once per day when your computer starts normally.
    Sorry for the long process, but having that original CD, as you can see sure would of saved a lot of time. If you can get a copy from Acer, that might save you some work, otherwise, the above options are a path to help find the ugly problem that's stopping Windows from booting normally,
    Let me know how it goes,
    Good Luck,
    Mark
  • Mark Taylor
    Mark Taylor Feb 18, 2010
    No, The steps are only to help find what could be wrong. All your data files will be fine, however since your having problems it would be a good ideea to back up your data files, while you can.
    Thank
    Mark
How do I unlock or reset my password? Cannot get past log in screen. Acer Aspire One
Hi laura dish
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
Sep 15, 2011 | Acer Aspire One PC Notebook
Acer Aspire 5535-5050 only starts in "safe mode"
when you get to safe mode try to do a system restore to a date that the computer worked............on xp it will give you a screen to enter safemode with yes or no options ........choose no to go diorectly to system restore...............if not xp look for system restore in the system tools folder on start menu or in control panel............the screen saver error is most likely because you are in safe mode.
Jul 19, 2010 | Acer Aspire 5535-5050 Notebook
Dell xps 1530 will get to log on screen and go blank
try logging in safe mode first upon turning system on tap on F8 then select safe mode, once logged in safe mode to a system restore to the date before this issue happend if system restore gives an error it failes tr going back to system restore in safe mode the do a disc defragmentation click start, accessories, system tools, system restore then select restore my computer to an earlier time then select the date when everything was working fine
Jun 04, 2010 | Dell XPS M1530 Laptop
Acer Aspire 3050. SAFE MODE PROBLEM
try keeping the username and password windows empty (blank) and click ok
Apr 25, 2010 | Acer Aspire 3050 Notebook
My screen goes blank and stops just before getting to were you put in the pass word...
Are you using Window XP, Does it display the Windows logo on start up, if so try to go to safe mode by pressing F8 on start up and select "Last know good configuration that worked" when option displays, and if it again it stucks then insert the Win XP disc and repair the installation.
Jan 31, 2010 | Acer Aspire 5050 Notebook
Acer laptop log on problem
When you get to the login prompt in safe mode, change the user ti ADMIN and leave the password blank, see if you can log in
If that fails, try ADMINISTRATOR
Jun 11, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer laptop ....lost power when going online....when i plugged it in and rebooted it goes to black screen and ask me to either repair or start windows normally...i tryed both but it still goes back to the...
try to go to safe mode first, after that, shut it down and reboot to normal mode, usually it will work.
If it don't work, go to safe mode and move your files/data to d partition and after that reload using alt+F10
Feb 25, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
