Question about iLO DVDRH04 DVD Recorder
ILO DVDRHD04 won't copy dvds. Says
ILO DVDRHD04 won't copy dvds. Says "Does Not support this function".?
  • 32 Answers
The 04 version of this player only uses DVD +R or +RW it will not reconize -R or -RW make sure you are using the approved DVD media for this unit
Posted on Mar 04, 2010
ILO DVDRHD04 PARTS
I understand that Funai corp makes these iLo DVD player/ recorders but when I spoke to someone, they did not recignize the model number. Their number and address is :FUNAI CORPORATION Customer Service Tel :1-800-605-8453 http://www.funai-corp.com 19900 Van Ness Avenue, Torrance, CA 90501 Good Luck
Jun 05, 2007 | iLO DVDRH04 DVD Recorder
How to hook up a laptop to ilo lfw to watch dvds
You can use VGA cable between the TV and your laptop. Attach the TV to the VGA port BEFORE turning on the PC, turn on the PC and hopefully it will detect the external monitor first, if not, then you have to use the HOTKEYS function (Fn key and One of the key with monitor symbol). The HOTEKEYS function will allow you to select both internal and external at the ame time , or just the internal only, or external only. You will also have to set the refresh rate for he external to be at 60Hz and the resolution not to exceed the maximum the TV can handle, should look to see what the native resolution of the TV is in PC mode.
Nov 03, 2009 | iLO IWT3206 TV
Cannot record on ilo dvd recorder with any blank dvds
Try another brand of blank dvd's a -R or +R as this is a compatibly issue
If all else fails buy verbatims as they are universal
Oct 12, 2009 | iLO DVDR05 DVD Recorder
I need a remote for my ilo dvdr04 recorder. where can i get it?
Go to walmart and get a Philips universal remote, they have the ilo code listed. I have two of them...even though the remote isn't set up like the original ilo remote, you can still record, burn, finalize, and edit. I have the dvdrhd04...which is going into the shop tomorrow to replace the dvd burner, but the hard drive still works like a charm.
Again, you'll have to play with the remote a bit....ARC gets you into the menu and (.) while playing will get you into edit mode, but into another menu when not playing a recorded item. I've used it so much now that I can barely use the original remote. ha ha. The perk is that you can set up your dvd, your tv, digital box and other things to run on one remote.
Hope this helps.
Denise
Apr 11, 2009 | iLO DVDR04
Remotew control
I also have an iLO DVDRHD04. I recently purchased the Philips remotes at Wal-Mart and they have the code for the iLO. You'll have to play with it a bit, but all the functions will work, even though they will not be labled in the same fashion as the original remote. I had to just press buttons and make notes until I got it figured out...but it will work.
Jan 17, 2009 | iLO DVDRH04 DVD Recorder
Ilo DVDR 05
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/e Someone said these were similar. Try the red/yellow/white cables. select that SOURCE. first select your recording length. I usually put mine on 3-4 hours and try to keep it from running to the end or you have problems. I use Rewriteable dvds, if you use reg discs be sure to finalize the disc so it will work in other players. I read if you are copying macrovision vhs to use the antenna input and it will copy it with that input. Just tune it to channel 4 or whatever. Forget trying to set the timer to record from tv. I never have success with that.
Jun 19, 2008 | iLO DVDR05 DVD Recorder
DVDRHD04 Timer setting
ON YOUR REMOTE, SELECT AND CLICK "TIMER". DETAILS OF THE SCHEDULE WILL POP UP. USE THE ARROWS TO SELECT WHICH ONE NEEDS CHANGING AND CLICK "ENTER". MKAKE YUOR CHANGES AND GO DOWN TO CLICK ok AT THE BOTTOM OF THE SCREEN.
Apr 21, 2008 | iLO DVDRH04 DVD Recorder
Liteon LVW-5045gDL+ dvd recorder will not burn to blank dvds
SAME HERE. I Have tryed a lens cleaner and seems to be working at the moment
Oct 09, 2007 | iLO DVDR04
iLO DVDRH04 DVD Recorder Logo
145 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
