Question about Garmin nuvi 250 GPS Receiver
How do I transfer routes to my Garmin nuvi 250
I have a Garmin nuvi 250 and have created a route which I would to drive in map source on my lap top and would like to transfer it to my GPS is this possible and how do I get it to my GPS
  • Garmin Master
  • 638 Answers
The Garmin Nuvi 250 does not support loaded routes. You'll have to load the waypoints, and then just go from one to the next, to the next. You can transfer the waypoints to the GPS unit with a USB cord.
Posted on Mar 04, 2010
My Gamin Nuvi can't unlock maps
Use a Garmin 1450
The Garmin Nuvi 1450 can be used while driving or walking.
While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets.
As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area.
Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass.
Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections.
Input the name of the state or county, if it is out of town.
Then tap "Spell city." Spell out the name of the city using the pop up keyboard.
Press "Done."
Enter the address number and press "Done."
Then enter the street name and press "Done."
The "Go" screen opens automatically.
Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address.
Follow the voice prompts and map highlight to your destination.
Navigate Using Coordinates
Tap "Where to?" and then tap "Coordinates."
Tap the coordinate you want to adjust/input a new coordinate.
Tap "Format" to choose the right coordinate format for the map you are using.
Enter the coordinates. Tap "Next."
Tap the green "Go" button to calculate a route.
Use the Map Page
Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn. Tap the bar across the top with the next direction listed on it to see a list of all directions.
Tap the plus or minus signs on the right side of the screen to zoom in or out.
Press the spinning arrow in the lower left corner of the screen to return to the main menu.
Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Hope this helps
Oct 29, 2012 | Garmin Nuvi 1450 GPS Standard Red LED Wall...
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
Transfering Routes to GPS device
Once you have transferred it using mapsource it won't automatically be in the custom routes. You still have to "import it from a file". Unplug your garmin from the computer then go to "Tools" then "My Data". That's where you should find the "import route from a file" button. It won't import if you already have 10 custom routes saved so you'll have to delete one.
May 03, 2009 | Garmin Nuvi 550 GPS Receiver
"No detailed maps found that support routing".
Please click on this link to obtain more information on this problem:
- Jim
SHARCNET-USA
Feb 20, 2009 | Garmin nuvi 350 GPS Receiver
How to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Nov 23, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Jun 20, 2008 | Garmin nuvi 200W GPS Receiver
I drive tractor trailers for a living this unit i bought keeps leading me the wrong way is there a way to enter the rout that i want to take using my lap top and the cord that came with it it is a garmin...
What do you mean by, "leading you the wrong way"? No, there is no way to transfer a route from your PC to the Nuvi 350. I believe that unit does have a Commercial Vehicle setting. This should take you only on routes you can travel with such a vehicle. You can find contact information for Garmin at www.garmin.com.
May 02, 2008 | GPS
Garmin nuvi 250 GPS Receiver Logo
303 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
