Question about Acomdata 500GB PureDrive USB eSATA 500 GB Hard Drive
My Acomdata 500GB Hard Drive won't start up. The light turns on when i hit the switch and it is blue, but it doesn't have the sound of starting up. My laptop sometime recognizes the that there is a device being attach through usb but the drive doesn't actually show up. Is this a power problem or something else?
  • kylemtsai Feb 01, 2010
    My Acomdata 500GB Hard Drive won't start up. When I hit the switch to turn it on the blue light is solid but there is no buzz like usual to indicate that is is starting up; instead there is a faint ticking sound. In addition to that my laptop is unable to recognize the drive only that there is a storage device connected. This recognition is very brief. It will recognize that there is a storage device for a few seconds then disconnect on its own. Needless to say based on other comments I have read, this seems like the drive is about to crash, but is there anyway to fix this or at least preserve the data inside? Please and thank you for your help!
4 Suggested Answers
SOURCE: External drive recognized as CD drive
You need to do a firmware flash. It worked for me. Here's the link to the fix.
http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Posted on Aug 29, 2008
Crankstart
  • 696 Answers
SOURCE: acomdata 320GB drive is not recognized
If the light is on it only confirms that you have power, if it doesn't work on other ports or another computer then it's likely the circuitry of either the drive or shell is damaged, take it to a computer store and have the techs swap it into a new shell(about $40). Then have them test it, if it works you're done, if not then it is the circuitry in the drive itself that is damaged and you will need to send it for data recovery if you want the files back.
Send me an update once you have tried this suggestions and let me know how you made out. If you require the help of a pro for the final steps, reply with your country and region and I will locate a reputable facility to assist you further.
Chris
Posted on Jun 04, 2009
Crankstart
  • 696 Answers
SOURCE: flashing red/blue acomdata 1 terrabyte external
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
ACOMDATA HD160U2E-509 NOISE AND FLASHING RED AND BLUE
My External HDD in your picture :D
Turn your HDD off & back on
Jun 11, 2011 | Acomdata 500GB External Firewire HD 500 GB...
I recently tried to access data from my Acomdata HD500 UF only to find that my Mac no longer detected it. The blue light comes on, but no fan sounds. Is it dead? Can I recover my old family photos,...
the hard drive may be dead.
stores like best buy offer services of data retrieval, although success is not 100% guaranteed, and these services generally are not cheap.
Feb 28, 2011 | Acomdata 500GB External Firewire HD 500 GB...
My external hd blue light just flashes and i dont have access.
Do you connect via USB or firewire? Can you / have you tried another connection method?
Does it sound like the disk is spinning normally, or is it making a heap of clunking noises or not spinning?
The most common problem (assuming it has power, which it obviously does because it has a blue light), is the USB cable. Do you have another that you can try?
Let us know how you go with that and we'll continue...
Apr 27, 2009 | Acomdata 500GB External Firewire HD 500 GB...
File transfer
Try turning everything off and then replugging the drive in.  Then start your computer back up/turn drive back on (if you have to).
Jan 31, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
My Acomdata (500gb?) external hard drive isn't working
Place it onto another computer, if you can see it and access it then plug it into a differant USB port on your computer.
Jan 14, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
HD will not start completely...
CLICKING SOUND IS THE HARD DRIVE ACTUATOR ARM THAT IS FAULTY.DEAD HARD DRIVE. CAN YOU SEE THE DRIVE IN DIVICE MANAGER?? IF YOU DONT SEE IT THERE IT IS DEAD AND HAS NO HOPE.
REPLASE THE DRIVE (SORRY)
May 20, 2008 | Acomdata 250GB External Firewire HD 250 GB...
External hard drive will not turn on
Try a new enclosure, the case is just that. A hard drive cannot actually repaired. You cant open it and fix it. It's either reliable and functioning or not. Purchase a new enclosure and test the old drive. Data recovery should be the last option..most places charge a down payment on a car, and most of the time ( in my 12 years ) its the cheap enclosure.
Keep me posted.
Oct 08, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata 500GB PureDrive USB eSATA 500 GB Hard Drive Logo
461 people viewed this question
Top Acomdata Computers & Internet Experts
terminalcon
Alun Cox
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
