Closed captioning taking the picture away from my tv
I can't find the close captioning on the remote of my Mitsubishi TS4553 in order to turn it off
  • Edye Feb 18, 2008
    Thank you. We tried the menu, but found it under the video button. A few pushes and we got to the closed captioning menu. Mom and Dad are very happy! They can watch tv again.
Edye- If the remote you have is the original for the unit you will most likely have to go into the main menu and change the caption feature,usually CC on/off, try this let me know, i'm curious now . cooltekFeb.18/08
Posted on Feb 18, 2008
  • Johnathon Mcclure
    Johnathon Mcclure Sep 10, 2010
    i dont have the original remote but i get into the closed captioning and when i select it there is no on/off it just cycles thru cc1-4 and t1-4
Dark shaded square area in center of tv picture - how do I get rid of it? I am at mothers and she has what looks like a 36 inch tabletop JVC tube tv probably about 10 plus years old. not able to remove tv...
I have heard complaints from some of my customers, “There is a black/gray box on my television, but I can still see the picture around the edges”. This happens to all of us and is a common symptom and can be fixed very easily. If you have a black/grey box in the picture, on the older sets they would be perfectly centered on the screen, but, on some of the newer sets the black/grey box can be in different places and can be different sizes on different sets.
Most likely the Text mode is on in the Closed Caption menu.
The way you can test if it is in Closed Caption Text mode, when you change the channels, the black/ gray box will not appear right away but it will take some time to show back up. This is a very good indication that the Closed Caption “Text” mode is turned on for your television. It just needs to be turned off.
To turn off the closed caption go into your menu and turn off closed caption (CC). This will vary from manufacture to manufacture; it should be in the options menu.
I have seen on some sets like Mitsubishi puts it under the Video adjustments button. So you may have to look around for it.
You may even have a CC button on your remote, which will make it much easier. Just press the CC button until the display indicates that CC it is off.
I hope that this tip helps you and that you enjoy your televisions for years to come.
Thanks for using FixYa
asnowman
Apr 19, 2010 | Televison & Video
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
On certain channels, a black box apears, like picture in picture. will go away if i turn up the volume, but comes back,
You have some how turned on the closed caption (cc) either on the TV or cable box,first go into tv's menu under closed caption and select off,that should take care of it,if not try the cable box.
Mar 21, 2010 | Mitsubishi WS-55805 55" Rear Projection...
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
Can't turn off captions on mitsubishi wd-62528!!
If you have the original remote it is in the Video Button Menu. Then select CC off, Or CC When muted.
This should work for you.
asnowman
Sep 19, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Close captioning stays on all the time.
if have remote or tv bo to menu scann threw it find captions and set off this may help
Mar 24, 2009 | Mitsubishi WS-55807 TV
Black square
Hello greeny11
get your remote and press menu and look for close caption. Turn off clase caption and this will go away. If you need close caption , set it to CC1
best regards
circuitcity
Apr 08, 2008 | Toshiba 50H72 50" Rear Projection...
Mitsubishi CS- 27303 closed caption won't turn off
the closed caption is not in the menu, it is in the video adjustments color,bright,sharp,ect. get to those adjustments and scroll until you see C.C. turn it off. i had the same problem but my whole screen was a black box,bought a new tv and everything. just figured it out today
Sep 26, 2007 | Televison & Video
Closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
Aug 16, 2007 | Sanyo DS24424 24" TV
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
