Question about Samsung SlimFit TX-S3082WH 30" TV
My volume stopped working on my panasonic viera plasma TV
  • 1,476 Answers
Make certain that it is not muted or turned off. If it isn't check to make sure that the audio type matches what you are watching. If you are on SAP and there isn't anything on the channel in SAP the audio will be dead. If all those check out you probably have a bad control board. $130 to $200 to fix. Let me know how things work out.
hardrocko
Posted on Jan 31, 2010
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
Why does my tv buzz? and how can i stop it?
Is volume high or low. Usually caused with high volume up. Believe it is a TV engineer fix up replacement.
Aug 10, 2014 | Panasonic VIERA TX-P50G30B 50AA€A Plasma...
I have a panasonic viera 50 inch plazma tv and cannot get the volume to work. i hit some button on the remote and now no volume. i do not have manual and the remote is from att uverse
Do you have a little symbol on the screen showing a speaker crossed out? If so you have pressed the 'mute' button. another press of the same button should un-mute it.
Jul 17, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TH-50PX60U Plasma is stuck on one channel. Only the power function works on the remote and only the On/Off function works on the TV. Any ideas??
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace. For further questions, please add your comment.
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
My volume just shut down on me. how do I turn it
go into menu of tv make sure speakers are turned on--if you are using a cable box turn the cable box volume up-let me know if this helps you-djstvrepair@comcast.net
Sep 04, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Sky + code
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 09, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Replace screen
This is a plasma panel and the part number is: MD65F10A1J and the cost is $3387.95 with a refund of $200 when the bad panel is sent back.
Dan
Mar 22, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Picture Refresh Problem
Used Panasonic Concierge Chat and they had me do this:
press volume down on the TV (not the remote) and then press menu on the remote for 10-15 seconds to bring up a check screen. After that, unplugged TV for one minute. Plug TV back in and set up for Home. Can exit out of the rest of the set up. So far so good......this was happening only periodically for me, so we will have to see if it works. I was also having to go to TV Video and select Component 1 (cable for me) every time I turned on the TV, but the above action fixed that. Now it goes to the input that was on when the tv was last turned off. Concierge is free. Very cool.
Jun 09, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Oct 06, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Samsung SlimFit  TX-S3082WH 30" TV Logo
321 people viewed this question
Henry  Thomas
Henry Thomas
