Question about Health & Beauty
White powdery residue on furniture and we're breathing it.
Respironics Concentrator DPI is hooked up to my husband's CPAP (Remstar). Our entire Master Suite is covered with a very fine, white residue. The furntiure and machine is dusted during the day and 2 days later a fine white dust or powder is on all the furniture, machine. What are we breathing? He was in the hospital for 4 days and no white residue because the machine was not used. I did that as a test to narrow down the source.
  • life48dancer May 11, 2010
    Is this residue normal dust? If not, I'd call the company, the EPA and get help immediately. I have a small machine that makes dust heavy so it falls out of the air and attracts to the machine and area around it. But you don't say the dust is only near the machine. Getting the dust out of the air would be good.
the dr
  • 447 Answers
SOURCE: DWU8260aax dishwasher, Maytag
What kind of soap do you use??? How much??
Posted on Nov 23, 2007
  • 139 Answers
SOURCE: Produces a ton of white dust... Why???
Your V5100N ultrasonic humidifier generates a fine mist by vibrating the water at an exremely high speed. The water doesn't actually evaporate until after the water mist is in the air. As the tiny water droplets evaporate in the air, the calcium and other minerals settle on your floors and furniture.
Humidifiers that evaporate the water in a filter wick, or with heat, do not generate dust because the water evaporates inside the unit and the calcium is trapped inside.
You can avoid the dust problem with your humidifier by using distilled water. Distilled water is available in most stores that sell bottled water in gallons...but be sure to choose "distilled" water, not "purified" water. Try the distilled water in your steam iron also...if you have one. It will last longer.
Posted on Feb 29, 2008
  • 677 Answers
SOURCE: new dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
  • 677 Answers
SOURCE: Dishes not completely drying and white powder residue left.
the problem is not the dishwasher but the water that actually is going into it. the white, powder substance is because of hard water. there is a affordable product out there called the dishwasher filtration system. it will filter the water going into your dishwasher and solve the problem once and for all!!! it is affordable and easy to install. www.dishwasherfilter.com
Posted on Feb 09, 2009
  • 615 Answers
SOURCE: White dust
if the unti working good and cooling then change the filter it may be too old.
Posted on Sep 08, 2009
How do i change presure setting - Respironics 1043237
If this is on a CPAP machine, I would not attempt to adjust this myself! The dealer where you got this from would be able to adjust this if it is needed.
Feb 19, 2017 | Respironics Health & Beauty
I have a code E-35
Just so you know there is a recall on this and may end up with a new one... read below
Respironics, the manufacturer of the Respironics REMstar Heated Humidifier, has received complaints of failures of the AC inlet connector on the REMstar Heated Humidifiers manufactured between December 2001 and April 2003. A small number of these failures have resulted in thermal damage to the humidifier enclosure, and there is a remote possibility that a thermal failure could result in the ignition of materials external to the device. For this reason, Respironics is asking that you remove the humidifier from its power source. You may continue using your CPAP device.
Respironics has decided to take voluntary action to mitigate the risk of failure. This action includes only the model 1005792, U1005792, R1005792, SC1005792, AC1005792, and 1007861.
This voluntary action is classified as a medical device recall, and is being conducted with the knowledge of the United States Food and Drug Administration (FDA).
WHAT TO DO:
Call Stericycle, Inc at 877-574-5038 or 317-275-7667.
Jul 02, 2014 | Respironics Remstar heater humidifier -...
What does a CPAP breathing machine actually look like?
cpap-breathing-machine-actually-look-yp05kui1bmoa5vtfxl1yxlad-4-0.jpgTHIS IS ONE KIND BUT THERE ARE DIFFERENT TYPES OF CPAP MASK
cpap-breathing-machine-actually-look-yp05kui1bmoa5vtfxl1yxlad-4-1.jpgTHIS ONE COVER THE NOSE AND THE MOUTH.
THE OTHER TWO THAT I KNOW OF COVER EITHER THE NOSE OR THE MOUTH ONLY.
Feb 13, 2013 | Health & Beauty
How do you know which CPAP snoring masks are best for you?
FOR ME I HAD TO HAVE A SLEEP STUDY DONE. IT IS A 2 DAY PROCESS. THEY HOOK UP ALL SORTS OF PROBS ON YOU AND MONITOR YOUR BREATHING. THE TEST WILL SHOW HOW MANY TIMES YOU STOP BREATHING. THEN YOU GO IN ON ANOTHER DAY AND THEY TRY DIFFERENT MASK DURING THE STUDY. ONCE YOU GET ACCUSTOM TO IT THEY MONITOR YOUR SLEEP AGAIN. THIS TIME, IF IT WORKS, YOU SLEEP THE REST OF THE NIGHT. FOR ME IT WAS WORTH IT.
Machine turns off
There are thermal overloads which protect devices. When it shuts down it cools down and will start up again. Check your inlet filter if you have lost your manual here is the on line version http://respironicsremstars.respironics.com/PDF/REMstarPlusUserManual.pdf
Feb 05, 2013 | Respironics Remstar Plus
How do i change pressure in CPAP
http://www.wikihow.com/Adjust-Pressure-on-a-Respironics-CPAP-Machine
I swear it's like no one's heard of google...
Nov 14, 2012 | Respironics SleepEasy Sleep Therapy System...
I have a REMstar pro CPAP machine that is making a high pitch chirping noise, very obnoxious. It's not the mask, hose or chamber. It seems to be coming from inside the unit itself. M
This will happen when a large, continuous air leak has beendetected in the circuit. Check the circuit connection for any leak. Youalso need to check the tubing. If it disconnected, then reconnect the tubingand press the Pressure on / off button to restart the airflow. If the airflowdoes not restart, the REMstar Pro may not be operating correctly. You need tocontact with tech person. Hope this will help you. Good Luck.
Aug 16, 2011 | Health & Beauty
Health & Beauty Logo
411 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
