Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do I get back factory settings on Magnavox Model 55P8288 big screen television
  • 102 Answers
Hi choose restore default settings in the menu.
Posted on Feb 01, 2010
Model 55p8288
maybe the push button switch is defected ,the solder of the switch is brittle , or crack or cold,try to resolder the switch, if not change it with new one.I incounter like this problem before in the switch , i only resolder the joint then its ok,,try this also maybe can help...
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Image too big
You have two possibilities; either buy the original remote or look up the code for 'universal' remote for that set here:
Remotes
If you can't find the code set for the remote & TV you have, look for a code set for one of the following brand names:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
These are all made and marketed by Funai.
Nov 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
We lost the remote to the tv. model no.55P8288 Serial no.67572804
go to radio-shack or wal-mart or any electronics store and they can set you up with a universal remote control, if not order direct from philips
Jul 27, 2009 | Philips Magnavox 20MC4304 20 in....
My phillips magnavox big screen tv model number 55p8288 doesnt have any sound when i turn it on
Check the audio setting to make sure the internal speakers aren't turned off. Check to see if it's set to use external speakers. If it is setup to run sound through an av receiver check all connections, make sure the receiver is on the correct input setting, and speaker wires.
Jul 05, 2009 | Philips Magnavox 55P9271 55" Rear...
Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 55p8288 tv not turning on
My problem is the same as the other two ppl. The Tv does not come on only the power button keeps flashing on/off.
Nov 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
55inch. magnavox projection tv. mod.55p8288
sell my the Lenticular Screen (the first screen) or find out what part you need and buy it from me.
danj34 [at] gmail [dot] com
Dec 02, 2007 | Televison & Video
Magavox 55p8288
Sell my the Lenticular Screen (the first screen) or find out what part you need and buy it from me.
Oct 27, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
267 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
