Question about Ovens
Control panel is blank - Ovens
  • 619 Answers
Bad oven control. Replace control or stove which ever is more cost effective.
Posted on Feb 02, 2010
Electronic control panel went blank and oven is beeping
The first thing I would do, because it is an "electronic" control panel is to unplug your stove, wait about 30 seconds, then plug it back in. Your Control panel may just need a reset and reboot.
If it is difficult to get to your plug-in, then go to your household breaker-panel box, and flip the switch for your stove to the off position for at least 30 seconds, then switch back to on. ...That's the same as uplugging and plugging back in at the wall.
Hope this helped hun ;-)
Oct 03, 2015 | Ovens
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
Rbd275pdb12
Control Panel has likely failed (circuit board). You can try removing the power wire from the back of the panel and then replug it back in to see if it resets the board, but Im sorry to say your likely going to have to remove and replace the control panel.
Dec 02, 2013 | Whirlpool RBD305PD Electric Double Oven
My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Nov 21, 2009 | GE Ovens
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
I´m having a problem with my wall oven FRIDIDAIRE FEB789WCCG. The front control module where the clock and buttons are have no power, its completely blank. when I push on the buttons nothing happens....
if you can reach inside the oven the fuse almost beside the power terminals usually like cylinderical shape and it has nominal values wroted on it , must be checked continuity at 1st by ohmmeter
thanks
Jul 11, 2009 | Ovens
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Control panel for oven functions has gone blank with occasional beeping sounds
The control panel may have a power issue. Replacing the board fixed my problem. It looks like 4 resistors and a ZD1 diode heat up and fail. The U1 chip could also be a problem. If you replace the controller it will cost around $225. Be careful of the key pad ribbon cable. They break easily. Another $186. Good luck.
Oct 16, 2008 | Whirlpool RBD305PD Electric Double Oven
Control Panel
Yes actually i do..... open the lower oven door next to the hinges are 2 small phillips screws, securing two long metal side trim pieces. remove trim. Exposes two more phillips screws Control lifts up and off then Make sure unit has been powered down !!!!!!!!! If the old control is totally blank there is a thermal fuse that has gotten too hot. PLEASE rate my solution...Thank you
Oct 02, 2007 | Whirlpool RBD245PDS Electric Double Oven
Ovens Logo
90 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
