Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Mildew/Stagnant water smell in washer
So, my washer has been smelling like wet clothes that have been sitting in there for a while. Since there haven't been any wet clothes in there, we been trying everything we can think of: running an extra spin cycle while it's empty to make sure there's no standing water, leaving the door open over night to let it "dry/air out", checking for a possible small clothing item that could be stuck somewhere. So far, nothing has worked. Then, I ran a load last night and moved it immediately to the dryer. When I went to wash clothes today, there was a pretty substantial amount of water sitting in the drum, which was not there when I took out the laundry last night. What is up with our washer??
  • Anonymous May 18, 2008
    black mold spots on door gasket. have tried cleaning with clorox/water solution and vinegar/water solution. nothing removes this. I even asked the service guy about it, and he was dumb as dirt. I'm thinking it's because I use non-chlorine bleach more than clorine bleach now, though at times I do use chlorine bleach.. Still would like to remove the stains.
  • Anonymous Feb 18, 2009
    I had the same problem as azjazz, except we just got our machine, used and have never used a front load washer before and I don't have the mildew smell persee.  So I was a little surprised to go down today and open the door and find like 2 1/2 inches of water sitting in the machine.  It was all out last night when we ran our first load and took the clothes out and put in the dryer.  I've checked the manual and it says nothing about standing water appearing "out of nowhere" the following morning.  Ours is an older Maytag, maybe 2-3 yrs old.  Was sitting in someones basement for about 1 1/2 years, not being used, so we are assuming there may be a little dirt or rust in the valves...I have run a load this morning and am going down now to check to see if there is water in there already.  OK...no water in drum, but it's only been 2 hrs since the last load.  I'll check back periodically to see if anyone is going to have an answer.  Many thanks for any input.
    Genius:
  • 3,587 Answers
You know, this does happen.
run it on a full cycle, warm, with either of these in solution.
baking soda, at 1/10 concentration
non chlorine bleach, at 1/6 concentration
you most likely need to do this more than once, until your nose is happy.
Also, consider doing this at least once every 200 wash cycles.
essential oils have same effect, and do a nice anti microbial as well.
we did this in commercial laundries all the time, as part of standard health code compliance issues.
Posted on Feb 18, 2008
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
Washing machine water doesn't drain and the machine smells bad
machine most likely has something caught in either the pump or one of the lines and you should clean out the pump with the smell s it a mold type smell or like a wet clothes type smell or a stagnant water smell that your smelling for the smell after you clean out the pump the drain line and the hoses at home depot they sell a product for washermachines that takes the smell out it is called AFFRESH this is one of the best products to use in washer machine they also make a type for dishwashers as well if you have anyfurther questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
p.s your pump could also be bad from debris sitting in the line
Dec 20, 2010 | LG Washing Machines
My clothes smell like mildew
Run a load of wash water with chlorine bleach ***Without adding clothes***. This will kill any spores in the system. Try to remove laundry as soon as it is finished and don't let it sit in the washer overnight. If possible, keep the door open when not in use.
Jul 01, 2009 | GE WPXH214A Front Load Washer
Smell in washer
Vinegar will fix this! Try pouring a quart of white vinegar into the washer, then run a cycle with no clothing in the washer. When the rinse cycle begins, stop the washer. Let it sit for about 30 minutes, then complete the cycle. That should do it! Afterwards, be sure to leave the door open to air dry it.
Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
Clothes have a mildew smell
Hello billpmm,
You are not alone with this problem. Seems that that everyone of the front loader washers exhibit similar characteristics .. the short story is that in order for a washing machine to be a front loader, they need to be water tight .. being water tight, they are also air tight and herein lies the problem.. any water left over from a wash cycle will sit in gaskets , nooks and crannies and eventually develop mold or mildew.. here is a link to product you may find that solves your problem
http://www.smellywasher.com/
or.. you can use the AFRESH tablets sold in Home Depot and other home improvement stores.. in either case.. these products will help rid that musty mold out of your washer..
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes/towels smell like mildew
Front load washers are so tight ( to seal in water ) that they tend to leave water in door gaskets and other places.. This water gets stagnant and can build up mildew etc..Home depot and other home goods stores sells a product called AFRESH and you use it about once a month ( with no clothes in washer).. It does help a bit..
Other techniques you can try would be to wipe down the gasket around the door opening after a wash is complete and to leave the door open between washes to let it air dry.. You should be using HE type laundry detergent and very little of it ( sveral drops is enough per load)..
hope that helps you...
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Washer smells like stagnant water
Open the door and let it air dry between washes doesnt have to be wide open but not latched either also run a hot wash with no clothes and 1.5 cups of bleach (pour bleach in the tub after it fills not in the bleach disp)
Sep 28, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
696 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
