Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
The red stand by/timer light on my Sony 32' Triniton flashes whenever I turn my TV on but the picture won't come up. What do I do?
  • 1 more comment
  • gr8fl1 Jan 31, 2010
    It flashes 7 times; three second delay, 7 more flashes and so on.
  • gr8fl1 Feb 01, 2010
    The model number is KD-34XS955
    Thanks for the suggestion; however, I'm a pretty low tech guy. Can you break it down for me? I don't have a meter or anything like that--only hand tools. Thanks very much for you help--Grant
  • Sony Master
  • 5,807 Answers
here is a guide for a start, may not be like the one you have,
but maybe applicable flyback , only if it is CRT type
b ) Service Manual could be of much help to you if you can
possibly have one, only with a fee.
c ) if there is no light indicator, or something is blinking in your front
panel of the TV it indicates a bad power supply.
d ) if the unit doesn't light at all, assuming the outlet is good,
then most probably the fuse might have been busted.
e ) if the fuse is busted , status is blackened inside, it is not advisable
to just replaced the said fuse, you might have other trouble , causing
it to fail.
f ) it might be a bad horizontal output transistor, have someone to
help you , look for it and properly check.ed.
g ) there might be other causes if your TV status light is blinking.
Here are your initial check list
h ) Confirm that the voltage of more than 23.0 VDC appears between
TP85 and ground on the A Board.
i ) Confirm the voltage of A Board TP91 is 134.6 ± 1.0 VDC
j ) Check Q502 ( 2SD2645 ) is not shorted
k ) post the number of blinks the TV
you are having and will try to update for more possible causes.
Let me know, if you needed further assistance.
Thank you for choosing FixYa for assistance. I hope that my
information proves useful to you. If so, please take a moment
to provide me with a positive rating. I'd really appreciate it.
Regards,
palaboy
Posted on Feb 01, 2010
  • 1 more comment
  • Rommel Cana
    Rommel Cana Feb 01, 2010
    Blinks 7 times
    Horizontal Deflection Stopped
    Either
    a ) a +B overcurrent is detected ( IC5007 )
    b ) overheating is detected ( Thermistor TH5002 )
    c ) check these circuits ( might be shorted )
  • Rommel Cana
    Rommel Cana Feb 02, 2010
    these might look like the TV you are having
    You will notice that there are yellow and pink circles.
    a ) Your target mission ( troubleshooting ) is the yellow circle
    b ) Pink circle will just be for checking if your troubleshooting and repair is OK.
    ( see sample guide on flyback , )
    Here is your flowchart to follow:
    It would be best to have a service manual, one like these @
    http://www.e-servicemanuals.com/product-...
    if you cant view properly the details on the image , or aid you in further diagnosis
    There are colorful guide and pictures that I'm sure you will appreciate and be safe.
    I wish I could tell
    you there was a quick fix or button to push that would fix
    the TV but that is not the case or the solution needed to get
    the TV operating correctly.
    those are just possible causes ,
    There could be many reasons. But, more Often, it would be
    on the Circuits Board. You need to Open the TV, unplug the
    wires from Circuits Board, pull it out and check it.
    More often, you would find either a Loose Solder
    connection or Leaked / Bulged / Swelled capacitor, shorted transistor,
    open/burnt resistor ( no resistance ) or a changed-value .. You
    need to note down the part number and you could order it
    online or go to your Local Electronics shop and
    purchase it. Once you solder it, it would be all set.
    Determine the symptoms; identify the cause of the symptoms;
    repair the unit to eliminate the cause
    Don't forget to check the circuit above, without those working , follow the flowchart.
    thank you for choosing Fixya for assistance!
  • Rommel Cana
    Rommel Cana Feb 20, 2010
    here is the Horizontal Output Transistor dimension
  • 10,594 Answers
Please count red standby light flash as there would be 3 seconds pause between flashes and let me know to diagnose problem.
Like red light blinks 4 times, pause of three seconds, again 4 times blinka etc.
Thanks.
Posted on Jan 31, 2010
  • Shahid Electronics
    Shahid Electronics Jan 31, 2010
    Question shows it is Sony KV-32FS120 that has no code of 7 blinks.
    Please recheck tv model number written at back of your tv.
    Shahid Electronics Feb 01, 2010
    OK, 7 time blinks shows Horizontal Deflection Stopped in TV
    Check horizontal deflection section, h-out transistor, flyback transformer and surrounding parts.
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Why does the sony triniton 40in not turn on but the power button flickers red
Is it blinking a code? * * * * * * * * * * * * This would be a 4 flash. Count them and post the flash code.
Mar 17, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
No picture but sound
how many times your ligth blinks?
5
if so you need to check your g2 voltage
let me know so i can get you more details
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Tv flashing stand by / timer
Sony tv's have a myriad of problems that prohibit the High Voltage from activating. The flashing red light indicates the standby circuits are functioning correctly. You problem lies in the H>V section.A shorted horizontal output transistor or even poor connections on the horizontal drive transformer could cause this problem. To properly diagonose this problem,it must go to a service facility that is familiar with Sony servicing. Usually Sony repairs are not cheap. It is imperative that only Sony original parts are used. Scrivitron
Jun 20, 2007 | Sony FD Trinitron WEGA KV-32FS320 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
260 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
