Question about Car Audio & Video
05 MBZCLK320 The volume knob spins but no sound
05 MBZ CLK320 The volume knob spins but no sound
If it's an aftermarket deck make sure the remote wires are hooked up correctly..some wiring harness' require you to hook up your headunits remote lead to the blue remote lead on the wiring harness...also if you have woofers attach all 3 of those remote leads together..
Posted on Feb 01, 2010
Buzzing noise from left rear inside trunk also causing radio not to work radio starts working when buzzing stops
That noise is likely due to a defective radio output amplifier, pull the radio and send it in for repair.
Jul 14, 2016 | Mercedes-Benz C-Class Cars & Trucks
Tip
Scratchy sounding volume controls?
If you have a scratchy sounding volume control or your channels cut in and out when adjusting the volume you are most likely suffering from a dirty potentiometer (volume knob) Fully disassemble your DTT2500 unit and liberally spray electronics cleaner in every party of the volume knob (and the other knobs as well). Let fully dry before reassembling.
on Nov 08, 2007 | Creative Labs DeskTop Theater DTT2500...
How to fix the volume knob ?
On the newer receivers that's all its supposed to do (i.e. no internal stop). If you spin it too fast it won't be able to adjust and it will do nothing. Spin it slowly for it to work properly.
Sep 03, 2014 | JVC RX-554V Receiver
Rattling sound on acceleration and idle,passed smog recently. Have 2003 MBZ clk320
have the following checked:
1. ignition timing
2. valve lifters / tappets
3. rod bearings
May 18, 2012 | 2003 Mercedes-Benz CLK-Class
CHANGING THE HEADLIGHT ON AN E320 MBZ
It pretty straight forward of you open the hood and look at the back of the headlamp. You see a metal clip right where the wiring harness plugs into the back of the lamp. Just take a common screw driver and pop the clip out (be careful you don't pop the clip down into oblivion as it does tend to spring out with a bit of force.) The clip is held in place by two star headed screws. You do not need to mess with these, just pop the clip out from under the screw head. I assume it will say something to this effect when you buy the new bulb but be sure not to touch it directly with your skin as the oils in your skin will shorten the bulb's life considerably.
Oct 01, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
I am having problems with the volume knob. The
That is a dirty pot switch.. The volume adjusting pot gets dirty.. Two things to try..
1.) With the unit off - spinn the volume min to max many many times at a rapid pace.. This sometimes will displace the debris in the pot..
If that does not work --
2.) Get some "tuner cleaner" in a spray can.. At Radio Shack or a similar store.. Lay the radio on its back so the volume knob is facing up.. Pull the knob off carefully.. Use short controlled bursts of the spray.. A few sprays and spin the knob min to max several times and repeat..
Good luck..
PLease dont forget to rate for your free question..
Aug 20, 2009 | Lasonic TRC-931 Cassette Boombox
1997 bose volume
While radio is turned off spray electronic contact cleaner behind volume knob while rotating knob . Make sure you have rag handy .
Mar 15, 2009 | 1997 Nissan Maxima
Volume control on unit
Kent, Unfortunately, it sounds as if the encoder is broken. The encoder is a digital input which takes the place of a traditional volume control, and is what holds the volume knob in place and spins. Since it works fine with the remote, that means everything else is ok, but you will have to replace, or have a tech replace, the encoder itself.
Sep 14, 2008 | Yamaha HTR-5550 Receiver
Sound
hi, ya, someimes the POT i.e the volume controller variable resistor loses its contacts with the carbon strip. tru using some switch cleaning solution( NoN Acidic) to clean the POT,let me know
Dec 07, 2006 | Yamaha GX-70 CD Shelf System
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
