Question about Irons
Euro-Pro Steam Press Model 5100
It appears to have a loose connection as it sometimes turns on and sometimes not. I can not figure out how to fix it or take it apart to see if there is a loose wire.
  • 22 Answers
Open the screws
use tester its a device.. when u connect it to electricity it glows.
plug it on and check the wires end
if one wire glows its ok..
other wise u hav to change wiring
Posted on Mar 17, 2008
Testimonial: "Hopefully I can get this open now. Thanks PC"
How much is a Euro-Pro steam press, model 5100 worth. used very little, excellant condition?
Posted on Jan 05, 2010
My euro pro ironing solution model 1000 does not heat up or allow steam to be released. It does make steam. What could be wrong?
The steam passages may be clogged, especially if ordinary water containing minerals was used to fill it. The instructions for your Euro-Pro iron probably specify use of distilled water.
Aug 24, 2016 | Irons
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Euro Pro Steam Iron
I'm having a problem with a Euro Pro Steam Iron as well. Thier customer service phone number is 1-800-798-7398. Hope this helps
May 13, 2009 | Euro-Pro Steam Generator EP8001 Iron
Euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Feb 05, 2009 | Euro-Pro EP1005 Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-pro iron steam genarator model # ep8001
I have a temporary solution that is working: Use WD-40 around the switch. Spray with the straw that comes with the WD-40. Let stand for a couple days, then turn the whole unit upside down and spray again, and let it stand that way for a couple days. If we could get inside, it could be more of a sure thing, but I had given up on mine and when I accidently hit the switch after siting for the last few days, , it came on!
Now for Sears to try to locate the tool that will open the case.
Apr 17, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro pro steam iron model G6118H
the preasure tank inside the iron could have a hole or the holes at the bottom of the iron are clogged up and needs to be cleaned.good luck
Jan 16, 2007 | Euro-Pro G6118 Iron
Irons Logo
398 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
