Question about LG Washing Machines
Door wont open on LG WD-8016C
Mine either. The handle seems to break easily. Try getting a butter knife and pushing in from the left hand side, this will undo the latch.
Posted on Aug 09, 2010
  • 1 more comment
  • scotteth Aug 09, 2010
    Sorry- i meant right hand side and pushing the latch towards the left :
    push like this in this direction <<<----
  • steve076 Apr 03, 2011
    Thank you, this worked
  • redbike92 Jul 17, 2011
    Well done, next step was going to be the hammer!? door is opened and i can now take off the door and get the broken latch repaired/replaced far cheaper than a service tech and callout would have cost. thanks redbike 92
Either will mine
Posted on Mar 23, 2010
Not sure how the spring goes on lg 8016c washing machine door handle
http://laundry.manualsonline.com/manuals/mfg/lg/lg_washer_product_list.html Go to this sight and find your manual and the directions should be there
May 07, 2011 | Washing Machines
Where is the lint filter for the LG Intellowasher 7.5kg (model WD-8016C)?
Hi just read your posting.I have worked on these machines before and I don"t recall this model having a lint filter.I know it has a drain pump filter and filters in the inlet hoses.Are you getting a lot of lint on your clothing?I will endeavor to find out definitively whether your model of machine has a lint filter and I will re post the solution.
Sep 18, 2010 | Washing Machines
Manual for LG wd-8016c . cold water is not going into machine
If you have cold water pressure to the machine and the valve filter is clear you probably have a failed cold water inlet valve. Replacing the inlet valve unit should fix the problem....Not unusual. Not a big job........Good luck....Nomess
May 28, 2010 | LG WFT1071TP Top Load Washer
My LG washer door wont open. Model is wd-14316RD. has done wash already.
There will be a delay of about 1 minute before it will open, this is normal. However if it will not open at any time try turning off at the power point, other than that you may need to get someone to look at it.
Apr 19, 2010 | LG WD-1080FD Front Load Washer
Lg wd-8013, all lights on at end of cycle door wont open
It sounds like you have a faulty interlock. This is what locks the door during the wash cycle.Sometimes they won't unlock and need to be replaced. There may be a pull tab inside the pump access area at floor level to get door open....Not a big job for a tech......Nomess
Apr 12, 2010 | LG WD-1045FH Front Load Washer
I bought my LG Intellowasher WD-8016C second hand and have no manual. Does it need to be washed occasionally with washing sda. There is a bit of mould around the seal. How do I clean this.
Manual suggests Exterior with household detergent. Do not use methylated spirits, diluents or similar products.
For internal, dry around the washer door and run washer through a complete cycle using just hot water... and repeat if needed.
Not sure about mould.... not in manual.
Nov 02, 2009 | LG WD-16115FD Front Load Washer
Top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Sep 15, 2009 | LG WD-16115FD Front Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Washing Machines Logo
808 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
