Question about Hussmann Freezer Gelato Pan Rack (For 12 Pans) For Model DCSG-12 or DCCG-12 Dipping Cabinets
I replaced compressor for a hussman refrig and its hums loud
The one i took out was louder on start up but quieter on operation ,i also replaced the L.L.drier & cap tube,pulled a vacuum ,charged w/r-134a ,22 oz is what manufacture asks for ,started up unit and it was quiet but suction pressure was really low about 8in vac , added gas till pressure reached about 10-15 psi on suction & 140 psi head (7 oz more),suction line started to freeze up so i recoverd some until ice went away ,subcooling is about 10 deg,ran ok for about two days but seems to be getting louder,noticed it ices up a little bit on start up at the suction service valve ,please help
    President:
  • 1,218 Answers
God day,
Some thoughts.
1. Are the evap fan motors running, and at full speed. That would give you abnormally low suction pressure.
2. Cap tube sized too small. or partial restriction in the dryer cap tube/dryer when brazing in the lines.
3. Low ambient. What's the temp the machine is running in.
4. Over sized compressor.
5. Moisture. God, 134A is touchy on that one.
6. Was original cap tube soldered to the suction line to create a heat exchanger. Needed on many apps. Definately would cause flash back on start up.
7. Superheat a little low, should be 12 to 15 degrees.
Posted on Jan 31, 2010
EWhat could be causing a Frigidair freezer to make a loud sound
have a technician check it out but a frequency hum indicates a faulty start/run capacitor for the compressor
if you continue to let it hum ,it may damage the compressor
Sep 23, 2015 | Freezers
Very loud noises
Check the rubber mounts under the compressor and look for any lines touching the sides of the cabinet. The gurgling and clunking are often normal. good luck. Roger
Jan 19, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Reaons for hussman freezer compressors failuer Model No:NLD 2
Normally compressors fail due to overheating. But just like any machine that may run 24 housr a day 7 days a week, the compressor may just wear out. Overheating is caused primarily by stopped up condenser coils. The condenser coil is the radiator like object that sits close to the compressor and dissapates heat created by the compressor. Also if the fan behind the condenser coil fails because of an obstruction or fan motor burnout the heat will not be dissapated properly. The compressor has protection built in that should shut it off during an overheating situation, but it can't protect it over a period of time where the compressor keeps trying to start and shuts down due to overheating. If you look at the condenser coil in many cases you will find dust and or grease build up so dense that no air flows through the coil. This is simply neglect or not knowing that the coil needs to be cleaned periodically. Also, if you have a refrigerant (freon) leak, your compressor will overheat. The cold returning freon helps to keep the internal components of the compressor cool as well as keeping the oil inside the compressor churning up onto the internal components. If you have a leak, it is not sufficient to just add freon every once in a while. Leaks need to be fixed by finding the leak and welding the leak shut. No refrigeration system should require "gassing up" other than the initial charge of refrigerant. Overheating can also be caused by a lack of air flow through the condenser coils because there is no space around the machine for air to flow into and out of the compressor compartment. If you have recently replace a compressor and it goes bad again, it may be burnout residue from the previous compressor that clogs the lines after a burnout. I hope this answers your question.
Oct 12, 2010 | Freezers
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Sep 14, 2010 | Frigidaire Freezers
The freezer has not been used for over a year,
The humming noise is most likely from vibration, check to make sure the freezer is level.
If it is level look in the back lower area there is a compressor, black component about the size of a bowling ball, make sure nothing has fallen on it or touching it causing the noise.
Apr 23, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Here are the unit's issues: 1. freezer won't stay cold and 2, a loud buzzing sound can be heard periodically Any idea what's causing these defects Thank for any help you can offer
Sound's like the start relay overload on the compressor if you hear a humming and a click do not leave plugged in get new relay/overload at you local part store or the compressor winding will burn up and a new frig will occur message me if this is the sound and inconsistent cooling temp b4 you heard the buzzing and click take you model # to the parts store an easier repair which is good....
Aug 24, 2009 | Kenmore Freezers
Freezers Logo
172 people viewed this question
Top Hussmann Freezers Experts
Dennis Boxerman
jasbo
jasbo
John Tripp
John Tripp
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
