Question about Ovens
I'm getting an F3 error on my 9 year old Kenmore range. Worth fixing, or replacing the range?
  • 619 Answers
F3 is usually the oven sensor. Worth the repair. Some times also the connection where the sensor plugs to the board has a faulty solder connection which is also repairable.
Posted on Feb 02, 2010
I have a Kenmore 66575014101 oven I get F3 fault code but I replaced the Temperature sensor and it still gives the F3 fault code
I found this on line don't know if it will help but it might send you in the right direction for testing to determine if it's worth repairing-- sorry
Shortly after a series of power failures I started receiving this error code. Looked up it online and did some extensive research. Everything pointed to a faulty sensor so I purchased a new sensor and installed it today. It didnt help, and testing my old sensor I determined it was also working. In the service manual it stated to do the following corrective action for the F3 - E0/E1/E2/E3 error codes:
Quote: 1. Measure sensor value (between connector pins) between 1000 ? @ 32° F and 2697 ? @ 900° F (room temperature approx. = 1080 ? ). If measurement does not correlate to real temperature, disconnect power, replace sensor and refer to steps 3-5. Also measure from sensor connector to sensor casing for possible short.
2. Trace wires and connectors to sensor, from control, then from sensor back to control. If all connections made and no wire damage, refer to step 3.
3. Disconnect power for longer than 30 seconds
4. Re-apply power and press BAKE and START/ENTER. Observe for longer than 1 minute.
5. If failure remains, disconnect power, replace control, then go back to step 4. I also tested the resistance of the sensors control panel wire harness connector and they are correct. Next step outlined in the service manual is to replace the control board. Sears has the control panel in stock for $177.47. This to me is not worth it over the cost of a whole new oven. Are there any fuses or anything else that could easily or cheaply be replaced before throwing out the oven. Thankyou very much in advance for your time!
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/99568-kenmore-oven-error-f3-e0-not-faulty-sensor.html#ixzz3JZIfN7gD
http://forum.appliancepartspros.com and this
Nov 20, 2014 | Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven will say F3 and shut down what does F3 mean no book?
Kenmore' F2 or F3 usually points to an open oven temperature sensor. If that is the problem, it's not an expensive repair.
Mar 02, 2014 | Kenmore Ovens
I have a kenmore ultra bake, model #665 75022101 and the oven doesnt work the code E0-F3 comes up. i have the manual and have tried what they said to do but it doesnt work. i have bought a new sensor
The error code message F3 E0 indicates an open oven sensor circuit. This is the component that regulates the oven temperature.
First disconnect electrical power to the range. Pull the range out & remove the rear panel to the control area. Unplug the 2 violet wires on P3 5-6. You will need to have a meter for testing, set the meter to read ohms (resistance). Place the leads from the multimeter across the 2 violet wires, the meter should read 1080ohms if the sensor is good. If you do not get the correct reading you will need to replace the oven temp sensor.
The oven temp sensor is mounted to the inside of the oven cavity. You will need to remove the lower section of the rear panel to access the sensor connector. Unplug the sensor & slide it back into the oven cavity to remove & replace.
Taken from...
http://www.managemylife.com/mmh/questions/120802-kenmore-range-displaying-e0-f3-error-code
Jan 12, 2012 | Ovens
F3 error code on Kenmore 911-45569690
Yep F3 I dont even have to look that up fault with oven tempreture sensor. If you perform an ohms test on it at room tempreture should read between 1000-1100 ohms if less then replace. Thanks again
Rick
Nov 24, 2011 | Ovens
What does error E1 F3 mean kenmore range oven
Hi....F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Apr 12, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Kenmore double oven flashing "door locked"
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range F5 and F3 warnings
May 13, 2008 | Kenmore 30169 Electric Single Oven
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
