Question about GE Televison & Video
I-purchased-a-general-instrument-catv-converter-model-dct2244/1161-and-hooked-it-up-to-my-cable-and-it-does-not-work.-hooked-up-a-friend's-same-model#-to-my-cable-and-i-received-all-kinds-of-channels.
  • 84 Answers
SOURCE: Switching from TV to CATV
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
Posted on Feb 06, 2008
SOURCE: I only get 82 channels when I should have 99
Are you sure that you only have 82 channels or does the receiver only go up as high as ch 82?
Posted on Mar 07, 2008
  • 21 Answers
SOURCE: I have purchased the converter
THE CONVERTER BOX HAS R.F. OUTPUT. JUST HOOK IT UP AND PUT THE T.V. ON CHANNEL 3.(OR WHAT EVER THE INSTRUCTIONS THAT CAM WITH THE BOX) YOU WILL NEED TO CHANGE THE CHANNELS WITH THE REMOTE THAT CAME WITH THE BOX. YOU MIGHT NEED TO SET UP THE BOX (SCAN FOR CHANNELS) THAT IS ALL IN THE INSTRUCTIONS THAT CAME WITH THE BOX.
DON.
Posted on Jun 15, 2008
  • 56 Answers
SOURCE: How to switch from TV to CATV
Hi teejo,
What is the model number of your TV and does it have a front panel menu button?
Posted on Apr 13, 2009
tvtek
  • 1284 Answers
SOURCE: Lost the remote
Without the Panasonic remote you can not get to those features to program these sets. I have included a link to purchase a replacement remote control. They aren't expensive and much easier to use than a universal remote. Please take a moment to rate my answer. Thanks...
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=pvdf2004&uuid=12592148630250
Posted on Nov 26, 2009
Switch from catv to antenna
Please explain what the problem is? You will need a converter box to do this, as the broadcast signal is digital and must be converted to analog. They (converters) are available on eBay for about $15.00
Jan 10, 2017 | Televison & Video
Do I need a converter box for a Hitachi 53uwx10ba TV?
Check to see what input the set is on--set in menu to catv or cable and connect with set on three if using a box---if not then auto program for channels.
If set on catv you should with the remote be able to direct enter a channel to see if tuner in set works or hook a dvd etc to a rear input to set to see if it works that way.
Nov 03, 2012 | Hitachi 53UDX10B 53" Rear Projection...
Caller ID not functional in Model KX-TG-9331T and 9332T
Do you have the converter that converts your caller id to U.S. caller id?
Mar 15, 2010 | Panasonic KX-T7633 Corded Phone
Can only pick up chanel from 2 thru 13,do i need a box converter all other tv get 98 stations
A converter box will allow you to get all the channels but if you are only getting 2-13 now go into the customer menu and I think you will find the set is in the AIR band and not the CATV band.
With the remote you should be able to move it into the CATV or cable mode and then if needed find and select auto program.
The fact you are only getting 2-13 means it is not in the CATV or cable mode.
If this helped you rate this solution as I do this here for Free.
SD TECH
Dec 07, 2009 | Pioneer SD-P6093K 62 in. Rear Projection...
Power light, on catv converter just blinks. No
hi
this type of problem occurs because of 3 issues..
1.colour wheel
2.jungle 45e3 ic on D- board
3.cathode ray tube...
check them...
thank u..///please rate it
Jul 04, 2009 | Televison & Video
Insigna ns-dxa1 converter
You might try useing a higher bandpass diplexer
Apr 24, 2008 | Audio Players & Recorders
Can't get to main menu
Before auto-programming, select set-up menu or tuning menu..
find selection possibly called tv / catv or normal / cable......
select CATV or cable............and then select auto-program..
If you need more help, I will need Make,model and mo / yr
built off the back of tv............................T.
Dec 23, 2007 | Televison & Video
Won't play songs
you should convert the song first to which your phone could support. simply downloading song (MP3 format) to your phone would only fill-up or consume lots of your phones memory.
Nov 15, 2007 | Sony Ericsson K600i Cellular Phone
Information about microwave leakage
Hi, you seem very concerned with your Microwave Oven "Leaking" & I would like to set your mind at rest. Now whilst all this is possible, in actuality it is a rare event. The manufacturers must meet very Strict & Stringent regulations regarding "Shielding" and "Protection" There are many safeguards inbuilt into the MO. Also the ONLY time that anything is "Emitted" is when the MO is actually being used. The Microwave Oven (MO) is for all intents & purposes is a "Radio Transmitter". Inside the MO, there is a device called a Magnetron, this device converts your mains Power into High Frequency Radio Waves, in the 2.5GHz Spectrum. These radio waves are exactly the same in makeup as ALL other Radio waves that are all around us all the time, and cause us no problems. You are prudent to be concerned but please rest assured the "Risk" from any "Leak" is extremely low.. even if it did "leak" in the first place. To answer your questions in turn... 1. No they do not... 2. No they do not. 3. Yes one can purchase a simple Microwave Oven "Leak Detector". Generally the only place that one may get a "Leak" from is around the "Door" seal.
Sep 09, 2007 | Microwave Ovens
Televison & Video Logo
100 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
