Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Along the bottom of the screen there is a blue-ish hue. This started a few days ago.
  • Kim Yearick
    Kim Yearick May 11, 2010
    I will need more info to help you with this. What if anything happened prior to the blue line showing up? Is it on all inputs? How old is the set? Let me know. hardrocko
  • 135 Answers
This is a failing optical block. Check ebay if you are going to fix it yourself. there is a rebuild service listed.
Posted on Feb 01, 2010
Why does my Samsung LED TV now have a permanent blue hue to its picture?
The t con board digitizes your picture and is responsible for anything you see on the screen including any and all anomalies. I would go that route TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Samsung Televison & Video
Blue-ish hues in left corner and middle of tv. getting worse sony kdf-55wf655
The Optical Block assembly must be replaced to fix this. This assembly runs around 800.00.
It has been a common problem and Sony had a factory recall on the Optical blocks but I believe that has expired over a year ago. To double check on that you can call them at 1800-222-sony.
I hope this helps,
skyassoc
Dec 08, 2010 | Televison & Video
Problem with sony 60" rear projection TV
I'm afraid, it is problem of optical block unit (light engine) that produce picture by 3 lcds inbuilt, the blue lcd and its related uv filters become defective and causing this kind of blue hue on screen.
Complete optical unit block (light engine) will be replaced by qualified tech to get tv fixed, light engine is costly part so ask an estimate before sending tv in.
Thanks.
May 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue hue accross bottom of screen - Sony KF-50WE610
You can try doing this, turn on the Tv and select the service menu, if that tint also shows on the menu, it's most probable to be your DMD board, but if it doesn't it might be the video board..
Jul 03, 2009 | Sony Televison & Video
BenQ PB 6100 .. blue hue on everything !
Most likely (90% sure) you need a new Main Board.
This Board is for sale on Ebay... http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170296659472
Nov 08, 2008 | BenQ PB6100 Multimedia Projector
Blue-ish tint suddenly ?
the solution is as its follows: :)enter in
Factory Menu
1. How to enter factory menu:
2. Hold press "UP" button until the "Lamp hours info." OSD display on bottom-right of screen.
Press keypad <Power> and <Blank> key simultaneously again, then enter Factory menu.
enter in fan menu and increse the speed of fans.
paul@ula.ve -> had to use the already written text...:P
3. with the keypad look for the menu that says <more options> on the bottom of the osd. once you are there go for the option HARD RESET.
4: also look for the option where its says SOFT RESET. its on other tab ... shut down the projector. take the power cord off the 6100. wait for about 10 seconds. plug it again and there you go...it works again.!!
francisco.arana@gmail.com
Oct 11, 2008 | BenQ PB6100 Multimedia Projector
Blue hue on bottom of screen We have the same problem. A blue hue extending the bottom of the screen and now is working its way up the middle .
call SONY at 800 222 SONY and explain it to them and be prepared to have your TV fixed for free !!! the projection block is faulty do to outsourcing on that part for a limited number of tv's an mine was 1 of them , SOny took care of everything !!! good luck
Feb 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
On bottom of screen, sound like a bad lite engine. Average cost
$600. Part number A-1084-658-A
Best regards
Circuitcity
Dec 26, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
