Question about Dell Dimension E310 PC Desktop
DEll E310 fan make strange noises at various times. How can I replace the fan?
  • Dell Master
  • 5,660 Answers
You didn't state which version you have, Slimline, Mid-Tower, or Desktop.
I'll give you the link to the Dell Dimension E310 Service Manual, and we'll go from there,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
FIRST:
Computer off, unplug the power cord from the surge protector, FIRST, then unplug the power cord from the back of the power supply. (Back of computer)
Unplug all cables connected to the computer. If you are not 100 percent sure where they plug into, now is the time to make yourself a chart, and add notes.
Work on a table, open the computer case.
(Cover Release Latch button on the rear of the computer, top side. The Right side cover opens.
Tilt it out, lift it up to remove. Or on the Service Manual main page, scroll down to Removing the Computer Cover, and left-click on it)
With the computer cover open TOUCH the metal frame of the computer case, to relieve your body of Static electricity.
(Static can fry out your computer's hardware components, and you probably won't see it, or feel it)
1) The Floppy Disk cable has to be partially removed.
2) The Processor's Heatsink Assembly has to be removed.
3) The SATA harddrive cables, need to be slipped out of the top of the Fan assembly cage's, squeeze connectors.
(This will make more sense, once you view the SATA harddrive's cables, and where they go across the Fan Assembly)
4) Then you can access the Fan Assembly, to get to the Fan.
A) With this Dell Dimension model, you have to remove the Floppy Disk flat ribbon cable, to access the Heatsink assembly, that sits on top of the Processor.
Remove it from the Floppy Drive ONLY. (Not shouting) Leave the cable connected to the motherboard.
You also have to slip the Floppy Disk's flat ribbon cable, out of the connector tang, that is on top of the Processor's Heatsink assembly.
(Flat steel tang, that is part of the Heatsink Assembly's frame, or cage. Pull up on the side that faces the rear of the computer, slip the Floppy Drive cable out)
This information is more easily seen, if you view the illustrations for - Removing a Floppy Drive.
On the main page of the Service Manual, scroll down to Removing and Installing Parts, and left-click on it.
On this page scroll down the left column, and left-click on - Floppy Drive
B) Removing the Processor Heatsink Assembly:
The Processor Heatsink Assembly is essentially a U shaped metal cage, that has a Heatsink attached to it.
There are 2 screws that hold the front of this metal cage down, and when removed, the cage itself tilts towards the Back of the computer.
(You may have to remove the Power Supply, to access the top screw of the Heatsink cage, or use an Offset screwdriver)
The tangs are triangular shaped, and are on the bottom of the metal cage, towards the Front of the metal cage.
The metal rectangular cage tilts back on two pivot pins, then it can be lifted up, and off.
In Removing and Installing Parts, left-click on Removing the Processor, for illustrations. (Or scroll down the page to this heading)
C) Removing the SATA harddrive cables, out of the connectors on top of the Fan Assembly:
This can be more readily seen by clicking on -
Installing a Harddrive, in Replacing and Installing Parts.
D) Now you can access the Fan.
The Fan is inside a shroud. The shroud is held to the Fan Assembly cage by plastic tangs, that are part of the shroud.
The tangs go through slots on the plastic Fan Assembly's cage.
The tangs are squeezed in, so that the hook end of the tang is able to slide out of the slot.
(It may be that the tang is pried towards the outside, so that it will clear the slot)
It's a lot of fun(?) trying to keep to tangs squeezed, so that you can slip one side of the Fan shroud, out of the slots.
This should release tension so that the other side's tangs will be able to slip their corresponding slots.
Buying a replacement fan will require a little homework, and searching various websites that offer a compatible sized fan. (Or peruse your local Mom and Pop computer repair shops)
You need to know the diameter of the Fan, as well as the thickness, (Or depth), of the shroud that surrounds the fan.
Also what type of connector it uses. 2 pin, 3 pin, or 4 pin.
The size of a fan, and the thickness of a Fan shroud, are usually stated in Millimeters. If you use the Inch system, go online, and use a free Millimeter to Inch Converter.
Here is one example, of a website that offers computer case fans,
http://www.directron.com/casefans.html
BEFORE you reinstall that Processor Heatsink Assembly! (Not shouting)
You MUST clean the top of the Processor's case, and the bottom of the Heatsink that sits on the Processor.
You will either see Thermal Paste, or a Thermal Pad.
If it is a Thermal pad, remove it, throw it away.
They are Junk, and cannot be reused!
I use an old credit card to scrape the top of the Processor's case, and the bottom of the Heatsink.
Stiff plastic, and is anti-Static.
I use Isopropyl Alcohol with Q-tips to clean the remaining thermal paste residue off.
(Rubbing Alcohol. 91 percent alcohol, or better is best)
Usually takes quite a few Q-tips, dipped in alcohol to do this.
Both surfaces must be CLEAN!
CAUTION!
Isopropyl Alcohol is EXTREMELY FLAMMABLE, and burns clean. The flame is virtually colorless. Use in a well ventilated environment, and with no sparks, or flames present.
The top of a Processor's case, and the bottom of a Heatsink are not perfectly smooth. To the human eye they may seem so.
There are microscopic pits, and valleys. These create Air Pockets.
Air is an Insulator, not a Conductor.
Thermal paste fills these voids. Thermal paste is an excellent Conductor, and transfers heat well.
The heat Must be transferred from the Processor to the Heatsink, so that the fan will transfer the heat away, from the fins of the Heatsink.
When a Processor becomes too hot, it turns off. (BIOS turns it off)
This is a Fail Safe feature that is built-in, to keep the processor from burning up.
Posted on Feb 01, 2010
Cpu fan stopped working on dell dimension e310
Did you accidentally knock the fans little power plug out of its connection to the motherboard?
May 17, 2012 | Dell Dimension E310 PC Desktop
Help -- CPU Fan Failure bypass or pinout?
Yep I have a link below you can order the correct fan from.
http://store.cwc-group.com/y4574.html
I had the same issue here, we have 20 offices all running Dells. These fans seem to be used only on dell systems.
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Tried changing keyboards , different usb ports, tried to restart totaly dead now, had to jump,running[fans only] lights on 2&3,still says keyboard failure. Time of day clock stopped . Invalid...
REPLACE THE LITHIUM BATTERY ON THE MOTHER BOARD IF THAT DOESN'T HELP LOOK AT THE FAN IN THE BACK OF THE POWER SUPPLY TO SEE IF THE FAN IS SPINNING IF NOT YOU WILL HAVE TO REPLACE IT
Jun 25, 2011 | Dell Dimension E310 PC Desktop
Dell e310 won't start after power failure ,orange
First up, don't buy a Dell again unless you like old **** with horrible support.
On Topic
- Did you pull out the keyboard and try another USB port (if it is an USB keyboard), or try another keyboard.
- If that doesn't work try clearing the CMOS (remove power plug, power on (to empty capasitors), either remove the CMOS battery and power on, or find a jumper to reset the CMOS. (since this is a Dell a that might not exist but check the manual).
At start up my Dell Dimension E310 begins a loud fan-sounding noise and won't stop
hi,
see to it all the connection inside not detach the FAn of your processor...or else, the inside of your pwer supply if have a dust or something that can attach to the fan..
thanks..
Jan 18, 2010 | Dell Dimension E310 PC Desktop
At start up my computer has a loud fan noise that won't stop. What is this and can I replace something to fix it?
You can open up the computer and find out which fan is causing the noise. Then take this fan to any computer superstore and they will find you a replacement. Usually fans are cheap.
I have fan failure. It has been making a strange
This is probably because the fan has most likely 'died'. I would replace the fan because you don't what your computer to start to freeze up, overheat etc...
Jul 10, 2009 | Dell XPS 200 PC Desktop
Yellow light flashes and Fan doesnt start
I think it may be a problem with the motherboard cause the power light should be green from what I remember. The fan isn't even turning on either which is very suspicious. Try another power supply if you have one handy and if that fails then the motherboard is bad. Even if your fan was bad, you would normally get video anyway before a warning message about the fan would come up.
May 08, 2009 | Dell Dimension E310 PC Desktop
Dimension E310
Im not sure if you are asking for the E310 drivers or the 4600c drivers, so I'm sending you the link to download drivers for both the systems.
http://tinyurl.com/2jpgqs (Thats for E310)
http://tinyurl.com/5jzwtd (Thats for 4600c)
All the best fixing your system
Mandeep
Jun 15, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension E310 PC Desktop Logo
836 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
