Question about Samsung TXM3297HF 32" TV
The cable connection on my tv broke off how can I connect back to the cable
    President:
  • 2,992 Answers
On most TV sets, the cable connector (also called an F-connector) is just press-fitted into the metal housing of the tuner (which selects the channels). It's not very strong mechanically and is pretty easily broken by tripping over the cable, moving the TV if the cable is too short, or often by cable technicians who overtighten the cable connection with a wrench.
The good news is that this can be fixed. There are two ways. The simple method is to replace the tuner. It's quick but costly as a new tuner may run $100. The second way is to replace the broken-off F-connector. On some sets it's possible to do this without removing the tuner, but not always. This repair may take a little more labor time, but saves the cost of the tuner.
Either way, this is a repair that's best left to a professional. Without the soldering skills and equipment needed, it's possible to do major damage to the TV and tuner circuit boards. I would recommend getting an estimate for the repair from a shop in your area. Yes, there are still places that fix TVs, but they are getting scarce.
Another possible "fix" is to forget about using the TV cable connection and use a VCR or DVR to tune the channels, and just use the TV's video and audio inputs. It doesn't repair the TV, but it gets you back onto the cable.
I hope you've found this helpful. Thanks for using Fixya!
Posted on Feb 01, 2010
3 Suggested Answers
  • 508 Answers
SOURCE: cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Posted on Jun 30, 2009
rsheehan
  • 69 Answers
SOURCE: Broken cable connector in the back of JVC tv
if the remaining piece was not part
of the PC board , which is light yellow
theres a good chance with a soldering iron
and a new female coax from radio shack
you could do it . or pay a shop 75.00 to
reinstall one for you.
Posted on Jul 01, 2009
Cable connection broke off bake of unit
if i was u id take to expert as i have had same problem once found cable was incased inside box very had to open so took to repair shop didnt cost alot
Nov 27, 2012 | Panasonic TH-42PX60U Television
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
Cable connector broke off in back of tv
Jun 30, 2009 | Televison & Video
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connecter broke off?
It would probably cost more to have someone fix it than just replace it.If you or someone you know can use a solder iron you might get lucky and resolder conections, but most times its too hard to get at the circuit board to affect repairs and the connector usually gets mangled so bad it won't fit right anymore. Or you can try to avoid using this connection and use a different input. But you would need either a cable/satellite box or vcr (with the same kind of connection that broke on TV) and change the input used on the tv to the new connection such as 3 wire AV connection (with the yellow,red and white wires)
Apr 26, 2009 | Sharp 25H-M60 TV
Cable connection broke on back of tv
YOu will need a box that will convert your coaxial signal (cable) into a another using either Composite (RCA wires) or component (Yr,Yb, Yg) outputs. Your local radio shack should be able to accommodate you
Apr 01, 2009 | Philips 32PF9986 32 in. HDTV-Ready LCD...
Cable connection part broke off in back
Are you talking about the part that connects the cable from the wall to the tv? I do not really understand which part on tv or vcr. It is true you can use the vcr as the tuner. You still have to connect the cable from the wall to the input cable jack on back of vcr. Then you hookup the R/W/Y rca plug- in cable from the back vcr output jacks (which are also color coded) to the tv's jacks. If you only have two jacks on the tv they will probably red and black. It doesn't really matter. Go from your video output on the vcr to the video input of tv, then use one of the audio outputs on vcr and go to the audio input on tv. It should work like that.
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Cable connection in back of tv broke.
part name -tuner -u can buy from electronics spare part market
Dec 26, 2008 | GE 27GT271 TV
Samsung TXM3297HF 32" TV Logo
1,628 people viewed this question
Jerry Greenberg
Jerry Greenberg
