Question about Water Warehouse Nsf Approved Sta - Rite Duraglas Pump
Have a 10 year old salt water pool with a PH1 Dura-Glas pump which is now not pumping enough water. Have recently fitted new filter etc. Does the pump head wear on this model and if so where do I purchase a new plastic pump head. Motor runs fine and there are no bubbles coming out of the pool outlets. Can you help me with this problem. Thanks John Webb
  • 990 Answers
If you had a crack in your basket then you may have a plugged impeller. You can reach the center of the impeller with a screwdriver and needle nose plier from the hole inside the pump pot.
If not you may have a problem with your impeller or the small "O" ring on the difuser. For this you will need to take the pump apart at the band clamp. Good luck.
Posted on Feb 01, 2010
Just installed a new pool pump. runs quiet, but does not seem to "pump"
Check the gate valves before and after the pump to make sure they are open all the way and to make sure the body of water is full enough so the pump does not cavitate the pump.
Rod
US Parts Center
888-521-6183
Feb 18, 2013 | Sta Rite Sta - Rite 1hp Dura - Glas...
How much sand do I need for 3/4 hp dura glas pump?
I would suggest 50lbs. If you filled it to capacity, it greatly reduces your water flow.
For more info, go to:
http://www.oskopoolnspa.com
Aug 13, 2012 | Sta Rite 21 Sand Filter System with 3/4 Hp...
How to replace motor
if you have the motor I recommend you have a pro do it. search your area for you're local pool pump motor repair service. cost should be around $20.00 this way its done right and protects the motor from getting damaged. ask them how to take better care of your pump and motor, that's the best pump you can get. sta rite dura glas
Prime the pump after any repair
Jay the pool pump reapair guy in longwood Florida 32750
Mar 12, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
I have a STA-Rite dura Glas H/L 1 1/2 - 1/4 hp pump. it is on it's 7th year. recently it has started to make a screeching noise. Can it be repaired or should it be replaced?
you can take your motor to the local Motor Shop and have them put new bearings in it. That is usually what causes that noise in the motor.
US Parts Center
Aug 21, 2011 | Sta Rite Pool & Spa
I need the wiring diagram for the point contacts on the back of a dura-glas 1 1/2 hp pool pump. thanks
7_26_2011_8_21_59_pm.jpg2 YELLOW GO ON 1 POST ON CAPACITOR , THE ONE RED GOES TO THE ONE SIDE OF THE POINTS THE RED/WHIT GOES TO THE POINTS AND TO THE OPEN LUG ON THE CAPACITOR .. SORRY ABOUT THE PICTURE , THE OTHER ONE WOULD NOT LOAD .. JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA .
Jul 25, 2011 | Sta Rite Sta - Rite 1hp Dura - Glas...
Our pool/spa pump will cut off for approx. 20 minutes several times during an 8 hr cycle. It never use to do this. The pump is around 3 1/2 yrs. old.
If the motor is very hot it could be shutting off due to a thermal safety device.
Anything that makes the motor work too hard and/or heat up will trigger this.
Blockage in the water lines
Clogged pool filter
Worn motor bearings
Lack of air flow around the motor
Weak or damaged motor windings.
A defective thermal limit switch will **** off the pump when the pump is within heat and load limits.
May 22, 2011 | Sta Rite Sta - Rite 1/2hp Dura - Glas...
Where can a find a new pump CHEAP? Current pump is Model C48L2P104 (18 years old). Serial 1B93. Voltage 230 HP 1.5 RPM 3450/1725 Amps 9.2/2.5 Frame 48Y Dura-glas H/L
A new motor and pump parts (if needed) would be cheaper than a whole new pump. Your motor is part number UQS1152R or if you just want a single, high speed motor you could use USQ1152 to replace it. You will likely need a seal and seal insert as well; part number 100 (it may have letters in front like AS100, PS100, etc) and J3-2. A whole new pump you should shop for part #P2RA5YF-182L.
For a quote on the parts from us you can contact us using thru our website at www.arrowpools.net. Otherwise, google those numbers to locate your best deal.
John
Jan 04, 2011 | Sta Rite Sta - Rite Duraglas In - Ground...
I have a 18 year old dura-glas pool pump. Recently, when turned on, the pump sometimes just 'hums' for about 3-4 seconds, then starts. The pump is primed and does not leak. There are no obstructions...
SOUNDS LIKE THE START SWITCH IS DIRTY OR IT MAY NEED A CAPACITOR it's a 161start cap THIS IS HANDS DOWN THE BEST PUMP YOU CAN HAVE ! THESE AS ALL PUMPS CAN BE TRICKY TO WORK ON, THIS COULD HAVE THE MOTOR REPAIRED WITH NEW BEARINGS AND A SHAFT SEAL AND DIFFUSER ALL FOR ABOUT 100.00 .. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY OR SHOP.. USE YOUR ZIP CODE IN YOUR SEARCH .. GOOD LUCK AND VOTE .. Jay
Jul 28, 2010 | Sta Rite StaRite Duraglas Pump 1 12 HP...
Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Sep 29, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
I have a sta rite dura glas 1HP pump and can't figure out how to get the impeller off. Can you tell me?
Lock the shaft at the end where you electrical connections are made (disconnected of course!) and spin it off counterclockwise.
Aug 11, 2009 | Sta Rite Dura Glas 3/4 Hp In Ground Pool...
Water Warehouse Nsf Approved Sta - Rite Duraglas Pump Logo
109 people viewed this question
Top Water Warehouse Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Water Warehouse Garden Expert? Answer questions, earn points and help others
