Question about Sharp 27U-S50 27" TV
Problems with Sharp 27U-S50 27" TV? trying to connect computer to tv. s cable is connected correctly but screen is blank on tv. Please help
JMuskovitz
  • 135 Answers
SOURCE: How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Posted on Feb 21, 2007
SOURCE: aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Posted on Dec 06, 2007
  • 298 Answers
SOURCE: VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Posted on Feb 25, 2008
SOURCE: Resetting V-Chip pin code
This what worked on my 27 inch model.. 1. Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN (9) on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be.
Posted on Aug 16, 2008
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
IPod player won't show on screen of my Sharp LCD LC-46D62U
Hello !
Guess the the cables are not proper connected or cables might have some problem ... or the ipod is not supporting to ur TV output ... first u try out with other Tv and confirm ...
Dec 10, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Need remote code for sharp 27U-S 100
Sharp TV Codes 173-095-171-004-006-012-029-111-112-113-122-196
Jun 26, 2011 | Sharp 27U-S100 27" TV
What is the universal remote code for sharp 27u-s50
Hi Luigi,
You may try the 3-digit code below.
SHARP Codes: 004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 21, 2011 | Sharp 27U-S50 27" TV
I am trying to connect my Laptop to my tv Screen,so as to enable the family to watch alltogether. can you please advise. Thankyou
This is a very simple procedure to do. All you need to do is follow the instructions that i give to you below.
1. Get a signal cable(the cable that connects your monitor to your system unit).
2. After obtaining this cable get one end of the cable connected to the RGB PC port at the back of your TV(the port that has similar plugs to the port in which this cable fits into at the back of your CPU).
3. Connect the other end of this cable to the same type of port on your computer. It is usually by one of the sides of the Laptop.
4. Your computer may flicker or go blank at first but don't worry if the display doesn't come back once this cable is connected at both ends.
5. Change your Tv output to the RGB PC output frequency.
At this point, all the display and activities should be reflected on the TV screen and you can put any movies or programs for your family to watch together.
If you are having any problems setting this up, let me know and please let me know if you were able to set it up properly.
Hope it helped you?
Jan 21, 2011 | Compaq Presario 700 Series: 1170B01...
Wii wont show on tv screen
Blank white or blank dark screen
  • Is this your first time hooking up the Wii console or have you moved it to another TV or VCR? If so, please click here to review our step-by-step connection guide. Our experience shows that the majority of these issues can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
  • If you have verified the connection is correct, and are still receiving a blank white or blank dark screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please click here for repair options.
  • Sep 25, 2008 | Nintendo Wii Console
    Hooking up my hp laptop to a sony trinitron tv
    Let me explain on how to connect the TV to HP notebook.
    There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
    Connecting notebook and TV with S-video cable:
    You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
    For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
    If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
    By pressing the same keys again will show the display on both the screen.
    Samething connecting with the HDMI cable, if your computer had HDMI port.
    If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
    If the issue persists, then you have to check with another cable.
    Note: No need to install any software on the notebook to connect the TV to the notebook.
    Aug 01, 2008 | HP Pavilion dv6000z Notebook
    Feb 20, 2007 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
    Sharp 27U-S50 27" TV Logo
    43 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
