Question about Toshiba P25-S526 Notebook
Windows 7 on Toshiba P25-S526 PC and there drivers
    Guru:
  • 194 Answers
For any drivers not automatically installed with Windows 7 running Windows Update should detect most all of them. You should make sure to select all updates, including optional updates (not the language packs). The optional updates may include hardware updates which will ensure your hardware is using the best and most current software possible. If this does not detect everything, I would recommend going to the toshiba support website and downloading the remainder of the drivers from there. You should also make sure your laptop is compatible with Windows 7 by checking out Windows 7 Upgrade Advisor.
Good Luck,
NOLA Tech
Posted on Jan 31, 2010
My Toshiba P25 s526 will power on. The AC is connected. The ac and battery lights are on. The battery discharges and the unit turns off with in 2 min.
Ok take out the battery and plug the AC in and power on to see if it works. If it does then it shouldnt go off after 2 min. but if it doesnt power that means there is a problem with your AC that is why it turns off.
I hope this solution has been helpful.
Sep 26, 2010 | Toshiba P25-S526 Notebook
I recently installed windows seven and now it doesnt give me the option to connect to the internet via wifi,i also looked in device manager as it is not listed.
Hi, the problem here is that your pc was not designed for windows seven. You can try downloading the latest driver for your device, or you may need to use a plug in to usb, to get wifi. Also for windows 7 you will need a minimum of 2Gig of memory.
Aug 29, 2010 | Toshiba Satellite P25-S5092: P25-S5092...
Mouse pad on laptop not working after install of new hard drive and os. usb ports also not working.... any ideas as to what is going on inside there?
  • “Hi, “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the "Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
    II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
    III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver, "Update Drivers, click Apply and (OK).
    Note: Restarting the computer will configure system changes.
    "Rating the solution is your way of letting me know if it (helped or not), thanks."
May 05, 2010 | Toshiba P25-S526 Notebook
After a re-install of Windows XP, the Standby option has been disabled (grayed out). Am unable to locate a Driver, and the Power Management Control Panel doesn't change anything. Can the Standby option...
HI there please install the display driver from driver DVD/CD. And restart your notebook, then you will find the enabled standby option & power management control panel. Thanks & waiting for your feedback.
Feb 12, 2010 | Toshiba P25-S526 Notebook
I have a Toshiba P25 that does not detect the dvd drive. The drivers have been downloaded
Maybe your operating is got missing windows files for the dvd drive try to repair the windows that you are using then try and see whether it appears or go into CMOS and check whether detects it
Dec 03, 2009 | Toshiba Satellite P25-S487 Notebook
Screen is blank when starting computer
Need a longer explanation of your problem. What os is in computer. Is ac plugged in. Can you get into the bios? (Usually pressing F12 or something on bootup.)
Nov 07, 2009 | Toshiba P25-S526 Notebook
Cant get my unit to connect at wifi hotspots
Have you connect/pair your laptop with hotspot/access point ?
Before going into internet explorer, you should connect to the access point first.
Nov 03, 2008 | Toshiba P25-S526 Notebook
USB devices not detected
go to the bios and check the boot device order, if the option for usb boot is there makes it first, ortherwise make cd/dvd as your first boot device, ........... enable all the usb options available on your bios
Oct 10, 2008 | Toshiba P25-S526 Notebook
My laptop is a toshiba satellite P25-S526. I cant seem to get the power supply to charge the battery. I have replaced both the battery and power supply and those were not the problem. why wont my...
If you have a volt meter measure the power coming out of the power supply and make sure the outlet is good that you are plugging it into.
Try resoldering the connection on the circuit board where the power supply plugs into it. There may be a loose connection or a crack in the board that you could jumper around using a short piece of wire soldered around the break.
Aug 26, 2008 | Toshiba Computers & Internet
Shutting down
Does it cut out on battery?
How often does it cut off?
Does it just die (no lights or anything) or reboot?
Jan 14, 2008 | Toshiba (K000006610) for Satellite P25...
Toshiba P25-S526 Notebook Logo
326 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
