Arming:
Hold Fob button down until signals flash twice. The 'key' lamp on
the speedo will Blink to indicate the system is armed. If auto arming is
enabled, the key lamp will Stay continuously
lit for 30 seconds after the ignition is turned off, then the system Will arm itself.
Disarming:
'Double-click' the Fob, the signals will flash once and the
key lamp will stop flashing. If the Fob is lost or not
working, the system can be disabled by entering the
passcode. Without setting off the alarm, get the ignition switch
to accessory, hold down both left and Right signal switches
until the key lamp flashes rapidly, enter the first
digit on the left And use the right as an 'enter' key, enter
all five digits of the passcode and the system will Disarm,
if you screw up, the alarm will activate and you will have to wait ten minutes.
Transport Mode: Allows the
system to be armed with the motion sensors disabled
for service, Trailering, etc. Turn the ignition switch on,
arm with the Fob, turn the ignition off and Arm once again
with the Fob. Signals will flash 3 times to confirm
arming, All other functions of the alarm system
require entering the configuration mode. This is done
by Disarming the system, run/stop switch in stop, flip the
ignition switch on/off/on/off/on Then push the left signal
button
twice. If power was disturbed to the alarm
module, The sequence may have to be repeated to get into
configuration mode. The system will respond by flashing out
the module type code.
(1-TSM, 2-TSSM dom, 3-TSSM
hdi)
Now that you are in the config mode, you can do the following.....
- To assign the Fobs, push the
right once (one flash) then the left once (two flashes)
Then hold down the Fob button until the system recognizes it.
Hold down the second
Fob until the system recognizes it. Both
Fobs must be assigned at the same time.
- To assign a passcode, use the fob to send a disarm command,
signal will flash once
To indicate the first digit, push the
left signal button and the key light will flash out the Value of the first digit. Pushing the left button will advance the value up through 9 and Will start over at 1. When
done setting the first digit, double click the fob again
and The signals will flash twice to indicate the second
digit, continue on through all five digits. Turn
ignition off to exit.
- To adjust the
sensitivity, use the fob to send an arm command (one flash)
then push the Left signal button once. The signals will flash
out the current setting, 1-4, push the left Button to
advance the setting, turn ignition off to exit.
- To extract system trouble codes, press the right signal
button three times,
pausing between Each press for the system
to flash once, twice, and three times
respectively.
Press the left signal button once and they signals will flash
out two digit
codes. Press and hold the left button to clear
all codes from memory, otherwise
turn ign off to
exit.
- To enable auto arming,
use the fob to arm the system twice, and press the
left button once. The system will flash the setting code, 1-disabled, 2-enabled. Press the left button to change The
To adjust between Sidecar mode and normal mode, push the
right button
twice quickly, Then the left button once and the
signal will flash out the current setting, 1-normal,
2-sidecar. Press the left button to change the setting, then
turn the
- To adjust the length of time delay before going into storage mode, use the fob to send an Arm command three times,
then push the left button, the signal will flash out the
current setting. 1-30 days, 2-60 days, 3-90 days, 4-disabled.
Use the left
button to advance the setting and turn
the ignition off to exit.
