Question about Brother LS2020 Sewing Machine
Bobbin won't come up!!!!!
I absolutely cannot get my bobbin thread to come up! The upper thread isn't creating a loop to catch the bobbin thread in. Needle at the highest position, hold the upper thread with my left hand, turn the wheel toward me, needle goes down, then comes back up. No bobbin thread!!!!! What else can I do. I've re-re-re-threaded the machine countless times. Please help.
  • 255 Answers
This is going to sound silly, but take out the needle and check that the flat side of the needle is facing the way the instruction books says it's supposed to. Unless the flat side of the needle is facing where it's supposed to for your machine (usually--but not always--to the rear, away from you), the upper thread will not make a loop.
(Cost me $85.00 to figure this one out.)
Happy sewing!
Robbie
Posted on Feb 01, 2010
Most of the time the bobbin stitch is correct. Occasionally there is a loop in the bobbin thread. Any suggestions as to what this could be?
Is it actually the bobbin thread that loops or is the loop appearing on the underside of the fabric as you stitch? If it is a loop under the fabric, that's usually an indication it is an upper thread issue. Thread irregularities that appear on the topside of the fabric are generally bobbin related.
First thing to try is installing a brand new needle. Verify it is the correct needle for the fabric and thread being used.
All About Needles
Sometimes, the fabric being stitched will "grab" the thread and hold it for a second before releasing and will cause a loop. In this case, a needle with a larger scarf and eye may be helpful.
You might also open the upper tension as much as possible, RAISE the presser foot and run a piece of UNwaxed dental floss through the tension disk a few times to clear out any gunk that may be stuck there. A piece of pearl cotton dipped in rubbing alcohol and squeezed moist/dry will also work.
Remove the upper thread. RAISE the presser foot and rethread the top thread from the beginning. Use only fresh, good quality thread--NO old or bargain bin variety! Try using the same thread in the top and bobbin. Make sure the thread is firmly seated in the tension disk and the thread path is correct. Check that there are no burrs or snags in the thread path that could be catching the upper thread. Especially, check that the thread is not catching on the spool "slit" that holds the thread when in storage. Every time the thread navigates around the thread spool, it could be catching on that slit just enough to cause a loop.
Try changing the bobbin. There could be something amiss with the current bobbin--could be nicked or could even be the wrong bobbin for the machine. Also, make sure the bobbin is loaded and turning the correct direction in the machine.
Set the upper tension to the midway point. This is usually the starting point, although it will probably require some tweaking. Test your stitch and adjust the tension so the upper and bobbin threads meet in the middle of the fabric. Neither thread should dominate one side of the fabric or the other.
Understanding Thread Tension Threads
Last thing to try is a different presser foot.
If you still have the intermittent loop, you might want to take it for service. Could be a problem within the tension disk.
Nov 05, 2016 | Sewing Machines
How do I get the thread from the bobbin to the needle?
If your machine is functioning properly, when the needle goes down into the bobbin area, the needle thread will catch the bobbin thread in a loop. (If you gently pull the upper thread tail, you will be able to pull the bobbin loop up above the needle plate.) If your machine is not doing that, then there is something wrong. Make sure the needle is installed correctly and both threads are threaded properly.
How and Why to Bring up the Bobbin Thread
Jan 24, 2016 | Sewing Machines
Can anyone help me with an idiots guide on engaging the bottom bobbin
Are you asking how to pull the bobbin thread up? Simply hold the thread tail from the top thread and gently handrotate the handwheel toward you. One full circle completes one stitch cycle. The upper thread should hook the bobbin thread and pull up a loop. When that loop appears above the needle plate, gently pull the upper thread tail, enlarging the bobbin thread loop and catch it with a sewing tweezer, pin, or even the point of a scissor blade to pull the rest of the bobbin thread to the top.
Nov 13, 2015 | Sewing Machines
My Sewing machine isn't catching thread at the lower bobbin.
check the needle /hook timing as this the indication that it is out
May 18, 2015 | Brother LS2125i Sewing Machine
Looped threads
Hello Rosemary
Looped thread on the underside are created by the upper thread. Loops on the top of the fabric are created by the bobbin thread. Whichever one is looping, has very little tension. This may be corrected by:
1. Re-threading the upper thread according to manufacturer's specifications.
2. Re-wind bobbin and re-set it into bobbin case and bobbin case area according to manufacturer's specifications.
3. Ensure that the needle is correctly installed and is the correct needle for the sewing machine.
4. Ensure that he bobbin being used is the correct one for the machine.
5. Double check that the tension on the upper thread is at the correct setting.
6. Double check that the tension unit is clean and free of dust, lint or lodged thread/s.
7. Double check that the bobbin tension is correctly set ... if you are comfortable doing so, otherwise leave it for a qualified technician
8. Make sure that he presser foot is down when stitching.
Please let me know how you go.
Happy stitching.
Nov 14, 2014 | Sewing Machines
The manual says the top thread should catch th bobbin in a loop but mine won't. what can i do ?
Make sure your needle is fully inserted into the needle bar and isn't bent or blunted.
Jul 19, 2012 | Brother Sewing Machines
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
Brother ls2125 bobbin not picking up thread
OK...I have an old singer (from 1964) so I am not sure whether you can do this...
I thread the upper thread as directed.
I stick the bobbin in the bobbin assembly as directed.
LEAVING THE SLIDE DOOR OPEN...I, by hand turn the wheel on the right hand of the machine counter clockwise (towards me). I want the needle go down. The thread from the upper part will enter the bobbin area and will form a loop that goes OVER the top of your bobbin to catch the thread from the bottom.
I keep turning until the machine has complete a cycle where the needle has started from the highest point, dropped to the lowest point (thus forming the loop that passes over the bobbin) and returns back to the highest point).
At this point you will notice that the thread is coming for from the bottom of the machine..I use a scissor to pull the the ends of the thread through. To the top. There should be two ends, one from the top thread, one from the bottom. If you dont believe me..jsut use a bobbin with a different color of thread...you will see what I mean..there will be two threads...one the first color and one the second color.
Good luck!!
Jan 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Brother LS2020 Sewing Machine Logo
145 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
