Question about Xerox DocuColor 12 Color Copier
Xerox workcentre pro 90 blows th 250v 15a fuse.Every replacement is blown when the machine is reconnected. All cables were disconnected from the distribution board. It still blowing the fuse
    President:
  • 3,085 Answers
I suspect a bare fuser wire. Not that many components get line voltage.
Posted on Feb 01, 2010
I have an Avanti gfit motorised t/mill.It has blown a fuse that is located on the circuit board.the fuse is rated 250volt/10amp.Where can I buy some more fuses, and how do I get a service technician to...
A sudden load can be enough to cause the fuse to blow rather than a short. Replace the fuse either with a 250v 10A Slow blw fuse or us a 250v 15A standard fuse. If it still blows then there is a definite fault. Motor Loading from lack of Lubrication etc.
Or a wiring short. Fuses are available from many suppliers. The shape of the fuse being used and how it clips into the board will be import and. Take a sample or an iPhone photo with you.
Feb 26, 2015 | Avanti Exercise & Fitness
UI/NC CABLE FAILURE RESET THE MACHINE CODE IN WORKCENTRE 7675
Your error is either a disconnected cable or a bad cable.
Xerox refers to the Operator Panel as the "UI"or User Interface, and the "NC" as the Network Controller. The cable you probably need to check or replace is 117K37660, coming out of the Operator panel back to the copier.
Sep 12, 2014 | Xerox WorkCentre 7665 Copier
No power in Mackie TH-15A
i) I assume the fuse you mentioned was in the mains plug - did you also check the fuse in the TH15A mains input socket? This is accessed by pulling out the tab in the bottom section of the socket (below the centre pin). This is a 3.15Amp antisurge fuse, 20mm type.
ii) If this fuse has blown, then replace it & all may be well ...... but if it blows again, then move to step iii).
iii) With mains disconnected, remove rear panel (outer screws) & check the power supply PCB for damaged components, especially R111 & R112 (100ohms). If the latter are burnt or open circuited, then the amplifier module may have blown.
regards, Dave
Aug 20, 2014 | Mackie TH-15A Active DJ Powered THUMP...
Blowing a fuse up turning the selector on position.
I'm guessing this is a large Pro Espresso machine. 250V/15A is a bit low as they usually range in 25A which should be on a 250V/30A line. Not your normal home outlet unless your using a washer/dryer outlet. You need an electrician to check if this much power is available on your premises. Check the nameplate rating on the machine to confirm this. If everything checks out and your still blowing fuses then the heating element needs checking. Blown (cracked) elements will short out in a tank of water causing over boiling and high steam pressure. Serviceman should check this as there are dangerous voltages present. Aloha! ukeboy57
Sep 16, 2017 | Miele CVA610
Can I use a 15A/32V fuse to replace a blown 15A/250V fuse
No! Unless you have read it wrong and it should be 320V. You can go higher than 250 volts but not lower. And you can go lower say to 10A and say up to 16 or 20A, though you should stay around 15A to be safe. If you do fit a 10A fuse at 250 volt and it blows straight away then it won't be the fuse that is faulty, but something inside the amp that has gone. As fitting even a 15A 250V will do the same. A 32 volt fuse in the mains section will burn out in a fraction of a second.
Dec 08, 2012 | Audio Players & Recorders
Fuse blown on incoming power replaced fuse but no luck
replaced the t8ah 250v fuse and it still blow when i turned on the tv
Oct 19, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
I have Xerox workcentre pro 128 copier machine. can you solve my problem? when i copy before appear this Error code 123-396.
That is a software related error, You most likely need to reload the firmware, or replace the hard drive.
You can try disconnecting all the document feed and scanner cables then reseating them. Other than that, your looking at a software issue.
Jan 28, 2009 | Xerox WorkCentre PRO 128 Copier
Workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Oct 22, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
Xerox DocuColor 12 Color Copier Logo
85 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
