REPLACE DOUBLE-USB-PORTS ON TOSHIBA LAPTOP: I am looking for a schematic OR AN EXPERT service REPAIR PERSON who has worked on the Toshiba Satellite P25-S526 or any Toshiba with USB Ports. I need to replace both of the Double-USB-Ports on the laptop. There are 2 (Two) double Ports; One on the side and one on the back. They are soldered directly to the motherboard. I have aready bought the dual-USB-port parts but need to compare the pin-outs from the originals to the replacements. A schematic would help because these boards are multilayer and I need to know if the ports are intersecting with hidden layers which would complicate my situation. (though not unsolvable) The parts I bought are through-hole but can be modified for surface mount. It looks like the existing parts are through-hole. I have some expertise in soldering small parts and some surface mount parts. I do not have experience with multi-layer printed circuit boards... and so I hesitate!!! Anyone Who has soldered parts or replaced parts on motherboards that can give me advice would help!! PLEASE PLEASE PLEASE !!!!! BY THE WAY; I WOULD LIKE TO THANK "EKSE" FOR HIS HELP AND SUGGESTIONS ... I AM JUST HOPING FOR A SECOND OPPINION SINCE I ACCIDENTLY POSTED THIS PROBLEM UNDER THE PRINTER CATAGORY THE FIRST TIME.
  • 542 Answers
My advice is that not to take any risk in soldering the USB ports on multi layered motherboard. Need to replace the USB ports with the help of expert engineers or service center. If anything goes wrong, then you have to change the whole motherboard.
Revert back for more assistance.
Posted on Feb 01, 2010
I want to hard wire my to Toshiba satellite l645d s4025 power adapter but don't know which wire is connected to the inside post, and which goes to the outer connection on the laptop power adapter port....
You could request a diagram from Toshiba OR take your Satellite to a repair shop where they probably work on Toshibas all day long and probably can rewire yours reasonably.
Aug 14, 2017 | Toshiba Computers & Internet
Usb not working for toshiba satellite l505d-es5025
If none of the ports are not working, simply go to the Toshiba Service center for the best possible guidance and suggestions.
Regards, Mrityunjay.
Jun 20, 2012 | Toshiba Satellite L505D Notebook
Ports/Interfaces on Toshiba Satellite Pro C660-171
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
Mar 21, 2012 | Toshiba Satellite Pro 6000 Notebook
2 usb ports on right side of toshiba satellite a505 loose, not usable because not in place
Hello geniet1:
If the USB ports are loose, then the computer is going to have to be disassembled for repair.You should have Toshiba, or a Toshiba authorized service center fix it. If I remember correctly,all you have to do with Toshiba laptops is just drop them off at UPS for repair.UPS sends them to Toshiba for free, and Toshiba returns the repaired laptop to you.
Apr 06, 2011 | Toshiba Satellite A505 Notebook
I Have Toshiba Satellite Laptop, i am continuously getting pop up message " Power Surge On Hub Port " A USB device has exceeded the power limits of its hub port. Please help how to stop this pop...
Remember the help below is only a fix for seeing the error message not for overdrawing the port.
To stop overdrawing the port you need to either use a power supply or a double USB cable.
To prevent seeing the USB Power Surge alert message, complete the following steps:
Click on START, Click on CONTROL PANEL, Double-click on the SYSTEM icon, Click on the HARDWARE tab, Click the DEVICE MANAGER button, Click the "+" next to Universal Serial Bus Controllers to expand the selection.,Right-click and select PROPERTIES on the Intel® USB UNIVERSAL HOST CONTROLLER (not the USB Root Hub),Click the ADVANCED Tab, Check the box that says: "Don't tell me about USB errors"
Nov 29, 2010 | Amstron Toshiba Satellite A80 Laptop AC...
Toshiba A45-S1202 The rear USB port does work, but the side USB ports by the upper left corner by the LAN port don't work. I did a BIOS FLASH, still nothing! Is this a DUMMY USB? No power to the upper left...
There are no dummy ports on laptops....could be a cold solder point on the motherboard connections or a wire connection is loose. There is also the possibility that the usb controller for that port has failed. Below is the link to the service and repair manual for that laptop......
http://tim.id.au/laptops/toshiba/satellite%20a40.pdf
Jan 28, 2010 | Toshiba Satellite A45-S1202 Notebook
I am looking for a schematic circuit for the Toshiba Satellite P25-S526/P25-S5261. I need to replace all of the USB ports on the laptop - lets just say my kids tend to pull out cords by "accident". I...
Below is the link to the service and repair manual. The schematic of the main bosrd is in the "B" appendix. Open the file, it is a pdf file and scroll down past the disassembly guide, When you get to the appendixes, it will be on B-1 and B-2, that will show the top and bottom of the board.
http://tim.id.au/laptops/toshiba/satellite%20p20-25.pdf
Jan 20, 2010 | Computers & Internet
I have a toshiba satellite A-135 laptop that will not recognize anything plugged into the usb ports
Check to see if one of the USB ports is damaged. Sometimes they can be damaged and have connections touching the outside metal of the port which actually grounds the connection and will cause the other ports to not work either. If it is connected then use a flat tip screw driver (*with the machine off and battery out*) to make it not touch the outside of the usb port and try "other" USB ports that aren't damaged and see if it works. If it doesn't then you are looking at needing a new motherboard. Locate your closest ASP and take in for service, you can find them at support.toshiba.com.
Nov 15, 2009 | Toshiba Satellite A135-S2276 Notebook
Need a motherboard for Toshiba Satellite A105-S4004
A105 motherboards are available on EBay
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=32&catref=C6&from=R40&satitle=+Satellite+A105+motherboard&sacat=-1%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=ZIP%2FPostal&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=32%26fsoo%3D2&fgtp=
At least one of those looked like an entire bottom plastic assembly.
Unless you are pretty computer savvy, you'll want a computer pro to replace teh motherboard.
Sep 09, 2008 | Dell Latitude D600 Notebook
My external microphone jack and USB's doesn't work on Toshiba Satellite
hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
Feb 12, 2008 | Toshiba Satellite A135 Notebook
42 people viewed this question
jasbo
jasbo
