Question about Microwave Ovens
The turn table does not turn - Microwave Ovens
  • 706 Answers
Since you didn't state the brand and model, I can only speculate that the spindle /turntable drive may be bound up or worn. Depending on the brand, you may be able to get replacemant parts to fix it but you will need to provide brand/model info on a repost.. If yoy remove the glass turnatble and the roller set... can you place a glass of water on top of the center spindle and run the micro for 20-30 seconds? While it is running.. does the glass rotate? If not... you may have a turntable drive motor failure... Need more info next time you post to assist you more accurately..
Good Luck
Posted on Feb 01, 2010
Do you have a glass turning table for daewoo microwave oven of the attached model in the photo
Just one recommendation. When it come to microwave, sometimes the glass turning table could be compatible with other brands. So I recommend that you edit this post and add a picture of the glass table that you want. That way you may have a better chance on getting help.
Jun 08, 2016 | Daewoo Microwave Ovens
How to clean liquid under round grate oven base?
tip it toward the back and be prepared to wipe up a big mess
Apr 12, 2015 | GE Advantium 120 Convection/Microwave Oven
Why is my turntable not turning in my microwave oven?
Is your microwave clean under the table? No stuck on food or anything? Does the the oven work without the table?
Does the little prop in the centre that turns the table move when there is no table on it? Try to carefully clean it and see if that helps.
Feb 17, 2015 | In Microwave Ovens
Turn table will not turn
I'd check to see if the turntable motor has continuity. If it does, check to see if 120 volts is being supplied to it. If both are o.k., then the motor has probably bound-up in some way internally. There's also the possibility that it has mechanically become detached from the hub that turns the glass tray.
May 06, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable in microwave does not turn. is it dangerous to keep using it?
hi. ther is no problem using your micro with the table not turning. as long as it still heats. the turn table is usually the first to go. i have had a couple like that and used them for a long time with no problems. you should be fine. hope this helps ease your mind. have a good day!
Jan 15, 2011 | Microwave Ovens
Turn table doesn't turn
Is the plate engaging the drive?
Jun 15, 2009 | Kenmore 63792 Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
Turn Table wont turn
if you can check the turn table motor for resistance. 90 percent would be a broken motor which you could replace. just look for the motor at the bottom of the microwave and race the wire back to the pc board.
i hope i was able to help..
pls rate me
tnx,
drcool
Jul 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 22, 2008 | Panasonic NN-S262SF Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
