Dell keyboard doesn't work on my dell computer- xp system have tried three keyboards and none work How do I fix this software problem? keyboard doesn't show up on control panel-under keyboards
  • 2,229 Answers
Is the keyboard a PS/2 or a USB keyboard?
If it's a PS/2, there is a good chance that you have a motherboard problem.
But try this: go to the device manager. In the control panel, click on "system" and then on the hardware tab and choose "device manager."
When that window opens, see if the keyboard appears. If not, you have either a motherboard problem or the windows system files are messed up.
If you have a USB keyboard, in the device manager you should see a bunch of USB devices. When I run into this problem, I usually remove the USB devices by clicking on each one and choosing to remove it. When the computer starts up again, it will find them and your problem might be solved.
If nothing works, you may have to use your install disk and repair Windows. Or replace the motherboard.
Posted on Jan 31, 2010
Dell inspiron 1525 functions keys are not working
The two most common input devices for the Dell Inspiron 1525 are the keyboard and mouse.
Although the mouse is an almost indispensable tool in navigating through programs and websites with your laptop, the keyboard offers quick shortcuts to open and manipulate files and information.
An unresponsive keyboard can indicate a deeper problem and require troubleshooting to narrow down the cause and find the proper solution.
Laptops are collections of complicated computer components and sometimes a file or two can become damaged and affect the way the machine behaves.
The first action to perform when things aren't working right is to reboot. When your laptop restarts, it essentially resets all the files and programs to the "starting" position and corrects any small errors that may have occurred during the last session.
Eliminate Conflicting Hardware
With an almost unlimited number of accessories, programs and software available for your 1525, it's possible something else installed on or connected to your computer is interfering with its ability to properly communicate with the keyboard.
Shut down the laptop and disconnect everything attached to it.
Power up and test the keyboard.
If it works, start reconnecting each accessory, one by one, until the keyboard stops working. You've found your culprit.
Try External Keyboard
To determine whether the problem exists in the keyboard itself a hardware problem or with the software that controls keyboard function, attach an external keyboard and see if it works.
If it does, the problem with your 1525's keyboard may lie in the keyboard itself, such as a loose cable.
If the external keyboard doesn't work, the problem may lie with the operating system's software that controls keyboard function, such as the drivers.
Update Software
Sometimes a laptop will stop functioning properly due to out-of-date drivers or other software. Always check Microsoft's website for any updates available for your operating system and check Dell's website for updates to the drivers and BIOS installed on your system.
In many cases, installing the latest updates will help correct issues and keep your system working smoothly and efficiently.
Check for Damage
Physical damage, such as a liquid spill and short circuits, can prevent the keyboard from operating properly.
Any amount of liquid spilled on your keyboard can cause a short circuit to the components and a sticky beverage such as juice or soda can cause the keys to stick and become unresponsive.
Clean the spilled liquid from under the keyboard fix sticky keys.
Laptop repair shops can do this for you if the task is out of your comfort zone.
Hope this helps
Oct 23, 2012 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Computer doesn't see keyboard as connected
Try rebooting system. Also make sure it (the mouse) was installed correctly
Sep 20, 2017 | Logitech MX5500 Keyboard/Mouse
I am trying to fix my boss' Inspiron Mini 1012 - the Webcam is not opening. unable to find the driver. Where can i download the driver for his webcam?
@christinwayn
This computer uses the generic driver for Windows XP and Windows 7 and thus there's no need to install a driver. If you need to re-install the Webcam driver, try to do the following:
For Windows XP / 7
1. Press the Windows Key+R on the keyboard (the windows key looks like this ray_tosh_1.jpg ).
2. Type devmgmt.msc then press Enter.
3. Expand Imaging Devices, right click on your camera and choose Update Driver Software
4. Click Search Automatically for Updated Driver Software
If this doesn't work, I recommend doing a System Restore (if it was working a few days or weeks ago, step by step guide here) or a System Recovery (if you don't mind starting from scratch - you need to press F8 simultaneously during boot-up > choose Repair Your Computer and click on your account > Choose Dell Factory Image Restore).
Good luck
Sep 07, 2011 | Dell Inspiron Mini 1012 Netbook...
Keyboard types very slowly and only after holding keys down for several seconds. very ftustrating
Sounds like you have too many things running possibly that's slowing the system down. You can try downloading malware bytes from www.malwarebytes.org and running a scan to remove any malware you might have. If that doesn't work, try that keyboard on another system to see if the problem is with your keyboard or with your computer.
Jun 24, 2011 | E-Machines AAFQ50400000K0 Keyboard
I have a xp pro system. The keyboard and mouse work during BIOS. They will not work in safe mode or in windows. I have tried other keyboards and mice. None of them work. I am running eyeonet dvr software....
somewhere in the bios you might have a setting for lecgacy or usb 1 or usb 2. just select a different option and try again. this sounds like a common problem but only the other way around. usually if the usb setting is wrong a keyboard doesnt work in bios but works in windows.
Sep 15, 2010 | Dell Computers & Internet
Dell Inspiron 6000 keystroke ''blip'' setting
Kids :) To solve your problem first you need to find out if there is any key that is broken or loose. What you could do is 1) turn off the laptop and wipe the keyboard hardly with a towel to release one of those broken keys. 2) if this doesnt work, you need to unplug external keyboard, and then goto start-> right My Computer -> Manage -> device manager -> keyboards -> rightclick standard keyboard and disable it.
Now put in your external keyboard and test your keyboard. Dont worry your mouse is still working and you can enable your onboard keyboard again. Try this and let me know if your problem is solved or detected. If your external keyboard works, i guess there is a problem with your onboard keyboard. you would require to service it. cheers.
Sep 14, 2009 | Dell Computers & Internet
F keys don't work on reboot. Work on Power on boot.
Turn your computer off.
Temporarily replace your keyboard/mouse with "generic" units.
Turn your computer on.
Check that the F-keys work.
Restart.
Now, do the F-keys work correctly?
Or, do you still get "keyboard failure"?
Jul 22, 2009 | Computers & Internet
Laptop Mousepad and Keyboard stuttering, slow
Whenever that happens to me, at least to the mouse pad I restart my laptop and it fixes it...
If not then perhaps it's a hardware or software problem, maybe you could reinstall XP over again, or you could, as a last resort crack it open and see what's goin' on inside or have someone check it out for you (I wouldn't go that far though).
Jan 30, 2009 | Dell Inspiron E1705 Notebook
Keyboard problems
Hi
I like to inform you that multimedia keyboards has no lock or special connection other that USB or PS/2 connection. But special multimedia keys can be assigned by its software. Make sure if you have the CD came with the keyboard if you dont have it still chance exist that you can go to manufacturer's website and obtain the software utility
Good Luck
Dec 31, 2007 | Dell Microsoft Windows XP Home Edition
Keyboard problems.
1. Restart the PC. 2. Hit F12 key repeatedly as soon as the PC turns ON. This will bring up the Boot Menu. 3. Select DELL Diagnostics. 4. Select the Complete / Full from the list of options. 5. Let the tests run which may take about an hour. Make sure you are there in front of the PC for the first 10-15 minutes, because it would need your inputs. 6. This will test the keyboard and USB ports too. 7. This will also verify for you whether the keyboard works when Windows hasn't started. 8. If all the tests pass and your keyboard is still working after sometime, you have issues with Windows: Start you computer in Safe Mode and check the USB drivers and the keyboard drivers. 9. Now, if you continue having issues even when you are running the diagnostics, you need to check your hardware viz. keyboard (try installing another keyboard if you have one) and the USB port. PLEASE REVERT BACK WITH THE RESULTS. I WOULD LOVE TO HELP YOU FURTHER ON THIS, IF THE ISSUE CONTINUES.
Mar 08, 2007 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Computers & Internet Logo
David Payne
David Payne
